- 23,818
K&N Drop In Filter: SI Model: K&N 33-2473
List Price: $ 69.00
K&N's replacement air filters are designed to increase horsepower and acceleration while providing excellent filtration. We make over 1,200 different replacement air filters for virtually every vehicle on the road. These filters are washable and reusable and are custom designed to fit into your existing factory air box. Their drop-in design means adding performance is simple. With most vehicles you simply remove the disposable air filter and replace it with a K&N. See applicable instruction sheet for details. Our stock replacement air filters for street vehicles are covered by our famous K&N Million-Mile Limited Warranty™ and will be THE LAST AIR FILTER YOUR VEHICLE WILL EVER NEED
info/comments/reviews
http://9thcivic.com/forum/threads/anyone-tried-the-k-n-drop-in-filter.3778/
K&N Drop In Filter: Non-SI: K&N 33-2473
List Price: $60.00
K&N's replacement air filters are designed to increase horsepower and acceleration while providing excellent filtration. We make over 1,200 different replacement air filters for virtually every vehicle on the road. These filters are washable and reusable and are custom designed to fit into your existing factory air box. Their drop-in design means adding performance is simple. With most vehicles you simply remove the disposable air filter and replace it with a K&N. See applicable instruction sheet for details. Our stock replacement air filters for street vehicles are covered by our famous K&N Million-Mile Limited Warranty™ and will be THE LAST AIR FILTER YOUR VEHICLE WILL EVER NEED.
K&N Short Ram Intake - K&N 69-1019TS
List Price: $ 499.00
Built for performance and show, the Typhoon® Air Intake System is a free-flowing mandrel-bent aluminum tube induction system designed to fit many sport compact performance vehicles. Each kit is proven on a rear-wheel dynamometer to increase horsepower and torque. Typhoon intakes come in one of three designs; cold air intakes (CA), short ram intakes (SR), or complete cold air (CCA) intakes which can be configured as either a cold air intake or a short ram intake. They come with an oversized High-Flow conical air filter designed to provide increased surface area and dust capacity. This extra surface area provides even more airflow at lower restriction than a standard K&N O/E replacement filter that is limited to the size of the factory air box. The oversize air filter also captures more dirt increasing the service life before a cleaning is required (up to 100,000 miles). Some Typhoon Air Intakes are not legal for use in California and other states adopting California emission standards while others are CARB exempt and 50 state legal. Check the K&N catalog or website vehicle parts search for specific CARB status.
info/comments/reviews can be found throughout this thread -
http://9thcivic.com/forum/threads/new-k-n-sri.4843/
http://9thcivic.com/forum/threads/k-n-typhoon-is-great-addition.5582/
Installation info from K&N - attached here
http://9thcivic.com/forum/attachments/69-1019_inst-pdf.8598/
View: http://www.youtube.com/watch?v=19k2ox2Hwm0
Injen Intake: SP1579P
List Price: $470.00
2012 Civic SI 4Cyl. 2.4L Tuned short ram air intake system with MR Tech., Air Fusion and Web nano-fiber dry filter
View: http://www.youtube.com/watch?v=4w3kwTh29bc
info/reviews/comments
http://9thcivic.com/forum/threads/injen-intakes-2012-civic-si-update-email-dyno.4149/
videos
http://9thcivic.com/forum/media/keyword/injen/
Injen Intake - Non-Si Models : SP1571P
List Price $445.00
2012 Civic 1.8L 4 cyl. 2012 Civic (9th Gen Tuned air intake with MR Tech & Air Fusion and nano-fiber dry filter
Takeda AFE Intake: TM-1018P-R
List Price $418.80
The all new Takeda Momentum Sealed Intake System produces up to 20HP and 18lbs. x ft. of torque over stock, while outflowing the factory intake by 42%. Unlike other Takeda intakes, this system uses a PRO 5R progressive mesh five layer filter for maximum airflow and convenience. This system uses a unique rotomolded sealed air box designed to increase airflow using the factory ram air scoop for maximum torque in all weather situations. Takeda intakes come complete with all necessary hardware.
Installation PDF -
http://9thcivic.com/forum/attachments/afe-pdf.10209/
Advanced Racing Technology ART: ARTCSI24CAI
List Price: $239.99
Every kit includes a never-oil air filter, and a hard intake pipe with a pre-welded CNC-cut flange for installing the factory mass airflow sensor. Once installed, your Civic Si will be even more enjoyable to drive. As with all our intake kits, you don't need to worry about "hydrolock", as you would with other intake kits. If you have any questions or special requests, please do not hesitate to contact us.
DYNO PROVEN: 15HP/8TQ GAINS OVER STOCK AIR BOX
@jnastii has this intake
View: http://www.youtube.com/watch?v=Ihi-p9dSI0k
View: http://www.youtube.com/watch?v=wgjQjYRAgGg
Advanced Racing Technology ART: NON-SI Models: ARTC18CAI
List Price: $239.99
Every kit includes a never-oil air filter, and a hard intake pipe with a pre-welded CNC-cut flange for installing the factory mass airflow sensor. Once installed, your Civic will be even more enjoyable to drive. As with all our intake kits, you don't need to worry about "hydrolock", as you would with other intake kits. If you have any questions or special requests, please do not hesitate to contact us.
DYNO PROVEN: 6-8HP GAINS OVER STOCK AIR BOX
Greddy Intake: 12559101
List price: $350.00
FG4 (K24) 2.4L - Momentum Series GReddy Air Intake System with sealed molded air-box with factory air scoop integration. Rounded-nose, dry element, cone filter and polished Aluminum intake piping with MAF attachment point
Greddy Installation PDF -
http://9thcivic.com/forum/attachments/greddy-pdf.10210/
Custom 3.5" Intake (Specifically For RBC Users)
List Price: Intake $365
List Price: Battery Tray $130
custom 3.5inch intake for our cars along with the battery tray for proper fitment. This is for RBC users & requires Hondata Flashpro
Contact randy at rstech for more info
http://rstech-racing.com/
AEM Cold Air Intake 2012+ Civic Si
MSRP: $325
Part# 21-716C
also available in polished -
Part# 21-716P
List Price: $375
AEM Intake Systems are designed to produce massive horsepower and torque gains as well as better engine sound when used as a replacement for the factory airbox and air filter. AEM intake systems are designed, tuned, and dyno-tested to fit specific cars and trucks. These kits usually include an oversized AEM Dryflow synthetic washable air filter for outstanding air flow, filtration, and performance while allowing easy oil-free cleaning
Installation vid
http://9thcivic.com/forum/threads/2...th-product-info-links.6472/page-5#post-226341
Product Page
http://www.aemintakes.com/store/product.aspx?prod=21-716c
AEM Installation PDF -
http://9thcivic.com/forum/attachments/aem-install-pdf.15823/
AEM Cold Air Intake - 2012+ Non-Si
MSRP: $319.20
21-714C - gray
21-714P - polished
AEM Intake Systems are designed to produce massive horsepower and torque gains as well as better engine sound when used as a replacement for the factory airbox and air filter. AEM intake systems are designed, tuned, and dyno-tested to fit specific cars and trucks. These kits usually include an oversized AEM Dryflow synthetic washable air filter for outstanding air flow, filtration, and performance while allowing easy oil-free cleaning.
Installation
http://9thcivic.com/forum/attachments/aem-r18-pdf.16897/
Takeda Retain Short Ram Intake - 2012+ Non-Si
MSRP: $274.80
This all new Takeda Retain Sealed Intake System produced 6hp and 7lbs. x ft. torque and outflowed the factory intake by 17%. This sealed design was opted over a traditional cold air intake, due to the fact that there is no fresh air running behind the front bumper. This system uses a PRO 5R progressive weave filter for maximum airflow and increased performance. This unique design uses a one piece rotomolded air intake tube/housing that snaps onto the factory lower air box for a quick hassle free installation. The lower air box retains your factory ram air scoop to keep cool air flowing for maximum power gains.
Product page:
http://afepower.com/shop/details_ne...model=Civic&year=2012&engine=1.8L&&brandID=78
List Price: $ 69.00
List Price: $60.00
List Price: $470.00
videos
List Price $445.00
List Price $418.80
Installation PDF -
List Price: $239.99
List Price: $239.99
List price: $350.00
MSRP: $325
Part# 21-716C
Part# 21-716P
List Price: $375
Installation vid
Product Page
MSRP: $319.20
21-714C - gray
21-714P - polished
Installation
MSRP: $274.80
Product page:
