- 23,791
Little explanation of how each photo was taken:
I tried to place the cutoff shield step near the center line on the wall. Each of the concrete slabs were 14ft wide. The midpoints are marked by pieces of paper at 7ft. These are just points so you can gauge each picture and compare their properties. All of the shots were taken on a tripod at 25ft from the wall.
Each photo was taken in manual camera mode. They were taken at 400iso at F8 for 2 seconds. If one picture looks brighter or darker, that is a characteristic of the projector. With each photo being taken with the same properties, the camera will not adjust to make them all look the same as far as brightness etc. There are zero adjustments to color, contrast, brightness, sharpness etc in photoshop.
H1 Bulb - generic 6000k ebay bulb
All other photos: Generic D2S 6000k ebay bulb (unless otherwise noted).
On to the pics
Mini D2S (orasm bulb)
Acura TSX Fresnel Lens
Acura TSX OEM Clear Lens
Mini H1 Low Beam
Mini H1 High Beam
Acura TL Fresnel Lens
Acura TL Fresnel Lens High Beam
Honda S2000 AP1 OEM Clear Lens
