zhongyang3
- 2
- Vehicle Model
- Civic Si
- Body Style
- Sedan
The dealership recommended that I replace the strut assembly because the nut at the top of my shock keeps slipping off, which means the threading is bad (I'm getting new sets tomorrow). If you look at the pics I took, you can tell that the bad side leans a bit and the good side is centered and the nut is all the way down. What could be causing this? And could my other suspension pieces be affected(ball joint, camber)? Would a replacement from a General retailer like AutoZone or Napa have decent replacement parts?
Back story: I hit a pothole on the front passenger side.
Good strut on top
Bad on bottom
Good strut on top
Bad on bottom
