- 55,520
- 23,812
Tires def look stretched on the suby.
I know this isn't a civic but is this considered meaty? And would that kinda fitment work on a civic? The wheels are ssr gtv02's... if I can get that kinda look I'm going to need these in my life
It's far from meaty. His rim is sticking well out of the tire.
I wish I knew I just ripped it offline [emoji85]
The 215/45-17 was the si wheel prior to them using 18's. You could easily run that, as it's the same setup the si ran.Hi all,
I have a 2013 Honda Civic. No mods. My wife uses it. The stock tires - 195/65-15 are woeful for highway runs. I am looking to increase grip. I was thinking about going for 16 inch or 17 inch alloys with a wider tire. I will not, I repeat I WILL NEVER EVER make any suspension mods now or in the future. Reliability is my main concern. I do not want to do any fender rolls and do not want to tolerate any rubbing in the front or rear s it will also be used for school runs.
I was thinking of a 17*7.5 rim and 225/45R17 or 205/50R17 tires as they are close to the existing stock size. Most websites recommend the 215/45R17. I am looking at the Continental ExtremeContact DWS06. I live in Spokane, WA and get a good bit of rains. I may go with dedicated winter tires on the stock size on the stock steel rims. What size do you guys suggest? I just need a wheel and tire combo that I can just swap into the existing car (after winter), align it, balance it and start driving. If 17 inch has constraints, I would not mind going with a 16.
P.S: This is a duplicate post. I have already posted it on the tire and wheel fitment thread.
Thanks Webby. All the confusion rose from the fact that the 225's seem closest to the factory spec and wont screw the speedo much. I guess ease of use trumps everything else.The 215/45-17 was the si wheel prior to them using 18's. You could easily run that, as it's the same setup the si ran.
You are correct that 225 is almost identical overall diameter to stock. You would be fine to run that size, especially on a 7.5" wheel. The extra sidewall will be a bit more comfortable too.Thanks Webby. All the confusion rose from the fact that the 225's seem closest to the factory spec and wont screw the speedo much. I guess ease of use trumps everything else.
You're correct there. 225/45-17 would also easily fit and be perfect for your speedo staying perfect.Thanks Webby. All the confusion rose from the fact that the 225's seem closest to the factory spec and wont screw the speedo much. I guess ease of use trumps everything else.
that's correct. No rubbing on stock suspension with either tireThanks Webby and Dpetro1. So I can assume that both the tires will have no rubbing or any other issues on a stock spec car and order them, right?
welcome to the forum
You should post all of your wheel and tire specs
