Coolant temp gauge recommendations?
fg3_colton
308
Tampa
Civic, LX
Basically as the title asks, looking for any recommendations on a coolant temp gauge, Doesnt need to be anything fancy. Thanks in advance!
Yep, there are lots of obd2 bluetooth adapters you can use to display on your phone.
There is less need for independent gauges now that the ecu/obd port can give you the info straight for the engine sensors.
If you are looking for something more permanent, you could do a standard electric gauge from autometer, I would stick with a full sweep electric. Of course you will need to tap into the coolant system somewhere.
I personally use the plx dm100 multigauge which is hard wired to the obd port but has a standard 52mm gauge face. It can display up to 4 sensors at once. I am currently using boost, ect, ait.
That's exactly what I want to do, I currently use Torque. But I'd really like to have something permanent. Will definitely look into them, thanks for the suggestion!
