Hi Guys, i want your help with this problem i got.
My Civic SI 2014 sedan got installed Illuminated Door Sills/Side Steps, they turn on when you open the door, only turn on the front ones, thats fine. But if the car is running and I manually turn on the map or dome lights, simply dont turn on, nothing happen, but when the car its turned on and the doors are open the map light can be turned on and off, just as it should be.
I think no voltage pass to the map light when the doors its closed.
Hope you understand me guys, i used a little bit the google traducer.
Thanks
Thanks
