- 55,515
- 23,810
throttle body has been proven to not be a bottleneck. vitviper did a bunch of dyno tests with various throttle bodies and saw no gains over the stock. Stock flows well.
traction control input is in flash pro manager-calibration, it looks like you can set it higher from stock of 2000revs when it starts cutting power while losing traction. Looks like I can control the traction with the tuner Hondata. I did notice it seems easy to drive with the traction control on and it would save some tire rubber and go actually faster with it on some times. You actually have best traction with the tires slipping 10% that's why setting it a little higher isn't a bad idea.
what about that button that turns traction control on and off? Doesn't the flash pro has a rpm setting that turns it on 2000rpm or you can adj it higher like 2500 that doesn't work-there is a setting that I saw? Very confusing. So you have to buy a flash pro traction controller for that to work-$600 too much for me.
Yes this is true, the Woffee is back-Started up the black SRT-4 monster today in Carb world,...Oh, so this is sunofwolf's lair.
