Hi guys. Been lurking the forum and the web for a while learning about cars (just got into them). I have a question about suspension. I want a flushed look like this, although the height may seem just a little too low as I go to the mountains a lot with this car. (Pulled the image off google)
I have a stock 2015 Civic SE sedan. I forgot where I read it and/or if it's car specific, but at what point of a lowered (height) car affect other suspension parts, like end links, to where they need to be changed to accommodate for a more lowered height? Will spacers affect end links too?
Also, I was reading that the bolt on the strut tower and the knuckles are different from SI and non SI. When buying coilovers online, I can't seem to find the size of the bolt used by the coiilovers and my car. Where do I find this info so I don't make a mistake buying the wrong suspension?
When buying on ebay, do i have to worry about coilovers being fake/replicas? Any tips or things I need to look out for when buying coilovers on ebay?
If you have any links for me to read up on, please do give them. I want to accurately learn as much as I can as I don't know any specifics about cars and the terms used. Thanks!
So far, I still need to read up on camber, caster, offset, end links and not sure what else is there...
Thanks to weeby's post and others too, I'm contemplating on getting this,
Megan EZ Street Coilovers For SI & Non-SI
MSRP $799
MR-CDK-HC12-EZ
The EZ STREET coil-over line up is aimed towards the more budget oriented enthusiast to offer the most basic essentials from an after-market coil-over setup, yet makes no compromises for quality and performance.
SPRING RATES:
F: 62mm ID; 200mm length; 6 kg/mm
R: 150mm length; 6 kg/mm
DAMPER SPECS:
F: 130mm stroke; 280mm length; M2 valving code
R: 160mm stroke; 260mm length; 44R03 valving code
- 15 Levels of Adjustable Damper Strength
- Aluminum Brackets paired with rubber inserts
- Rubber Dust Covers
- Adjustable Ride Height
- Conservative Spring Rates
- Single-Cylinder Design - monotube
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
MSRP $799
MR-CDK-HC12-EZ
SPRING RATES:
DAMPER SPECS:
