12 Civic Coupe Rear Bumper Damage
Discussion in 'Inside and Out' started by Verzerrung, Dec 27, 2018.
  1. Verzerrung
    Verzerrung Well-Known Member
    84
    Yucaipa, CA
    Vehicle Model:
    Civic
    Body Style:
    I've looked around on Youtube and the forums, but didn't find anything that I feel is similar enough or that could work without replacing the bumper. It is a pretty big cut at the very bottom and to the left of the bumper. Is there a rear lip for the coupe or a lip kit? Hopefully, I could get away with fixing it. Thanks for any info!
    [​IMG]
  2. aznboi606
    aznboi606 Well-Known Member
    352
    Atlanta, GA
    Vehicle Model:
    Honda Civic Si
    Body Style:
    You could put on a HFP rear lip, but not sure if it will cover it all.
  3. webby
    • 2018 Toys For Tots
    webby Administrator
    48,698
    Hard to tell how big of a rip that is. You could measure it. Problem with adding a rear hfp would be hoping it’d stay attached to that area, because it’s applied with 3m tape. I don’t know how far that’s ripped in comparison to where the hfp would stick.
  4. webby
    webby Administrator
    48,698
  5. Verzerrung
    84
    Yucaipa, CA
    Vehicle Model:
    Civic
    Body Style:
    Here are a couple more photos of the damage. I measured it and it is roughly 5.75 inches. The lip definitely seems to cover the damaged area, but the video didn't really show how cups around the bottom of the bottom.
    Are there any other full lip kits for the coupe other than the HFP that go all the way across the front and rear bumpers? Not really sure what a lot of people have.
    [​IMG]
    [​IMG]
    [​IMG]
  6. webby
    webby Administrator
    48,698
    https://www.collegehillshonda.com/instructions/civic/2013/2dr/rearunderbodyspoilers.pdf
    Check the pdf for install. It shows the install points in greater detail on how/where there are clips used to attach it, as well as tape. I don’t know if you can see any of the points without taking the bumper off or not, but you could check.
Share This Page
