- 55,520
- 23,812
What data do you have on the pads?
Very little. When I asked R1 for specifics they couldn't even give me a standard size so I could look for replacements. All I know is this blurb the salesman sent me when I was making a selection:What data do you have on the pads?
Thanks again @Nix. That's the sort of thing I was looking for (Porterfield reference).Well, cold weather performance may be a bit of an issue for you.
You posted that the optimal operating temperature for the pads is : 100-600°C.
Thats 212 F minimum. If it's really cold out those pads might not bite at all. Could be a little treacherous when you first start driving. I would suggest being quite careful and test the brakes out a couple times the first day it gets super cold out to see what they do. I would imagine they still have some brake to them but probably a lot of increased noise as well.
I guess if they have a more common street pad a set of those may be worth investing in for the winter. The other option in the meantime is to contact Porterfield brakes. They make custom brake pads and backing plates. You can either mail them one of your current pads and buy a new set of the street pads or, carefully trace the outline of the backing plate and fax them the paper. They will either be able to tell you which pads will fit that someone makes or they will make you a custom set to use with whatever compound specs you want.
Expensive? Probably. But give Porterfield a call. They are super helpful. I had custom shoes made once with a very aggressive compound. Since drum brakes suck, I wanted as much bite as possible.
I would really recommend buying the street pads for the winter since the current ones need 212F to function. I would hate for you to rear end someone or worse because your pads don't work when it's cold out.
Porterfield: 949-548-4470
http://porterfield-brakes.com/categories/shop/Custom+Brake+Pads.html
Interesting. It would not surprise me that R1, a CA based company, has never tested these pads in a cold AND wet situation. I bet these pads just aren't designed for cold or wet conditions. I was never very enthused with their pad selection and planned to get other pads anyways. Nbd, just more pressed for time than I wanted to be since, you know, winter is coming. [emoji12]http://www.pistonheads.com/gassing/topic.asp?t=965567
2 pages of comments about rain/brake pads
That's good to know. I saw wheel design effecting things noted but not confirmed in the link @webby shared above. Unfortunately, I was planning on making these HPD wheels my winter set and buying something with even thinner spokes for my new summer wheels, lol. But that is a consideration. I'll have to see how things go once the snow tires are on and it drops below freezing on a regular basis. New pads will likely be much cheaper than new wheels, even if they are custom made.I did notice my wet performance changed with the wheel I was running. Wide open design summer wheels let a ton of water in and the steel winters that had a very closed design had no issues. Might be something to consider also. If you have a second set of winter wheels or run OEM steelies you will probably have less of an issue in wet/snowy conditions.
Cleveland gets a fair bit of snow doesn't it? I'd imagine a tighter wheel design and good snow tires will make a noticeable difference. Just make sure you can clear those calipers.
I emailed them a few more times, especially after they didn't first respond and then again after I got to snap pics. If they don't get back to me Monday I'll be calling, a lot. One thing I haven't been very satisfied with is their customer service; But I've been waiting til everything is sorted out before I pass judgement on that end.Sema ended nov 3rd. Call them again
