'13 Hitch?
traxtar3
Member
4
2
Denver, CO
Does anyone out there have a hitch on their '13 Civic Si Sedan? I am looking for a good place to purchase one. I found one online, but it was for the Coupe. I don't know if they are interchangeable or if the '12 one will fit.
Any help would be greatly appreciated!
Don't worry, I wont be towing with it. Using it for a bike mount.
Hey, welcome to the forum...
I was able to get my hitch through etrailer.com
http://www.etrailer.com/hitch-2013_Honda_Civic.htm
They have several listed so you just need to choose which one is for your car Si or non-SI & coupe or sedan. Im pretty certain that the sedan Si & non-si are identical. A quick call to the company might be worth it.
Very easy install. No drilling or cutting. Took about 45min. I use mine for the same thing. I didn't even remove or alter the heat shield like the directions said I would need to. Little finagling and it was on.
I think the 2013 bumper could be a concern. That's the only possible issue.
etrailer lists 2013's now. Fitment should be spot on. They have a lot of install instructions and pictures with lots of angles on their website.
I have both lip kit and HFP suspension, a bike rack should be fine, unless you went hellaflush flush then you are screwed.
