jdmasf__ck
Active Member
- 2
- 2
***WIRE DIAGRAMS AND PINOUTS WILL BE POSTED SOON***
2014 Civic Si Navigation Head unit into a 2013 Civic Si (Non-Navigation)
I want to start this off with saying, if you plan to do a navigation swap into a non-navigation civic, you will really need some technical knowledge on wiring and electrical work!
After my countless hours of research day and night I had finally came to the conclusion that this swap IS possible, however I believe that I would possibly be the first to do it and would basically have to do this without any help or past experience. The help that I had sought for; either 100% doubted that this could be done or just completely ignored it. I am not going to mention any names of this but there is a person that I was referred to in the “eBay Community” that could possibly fabricate me a custom harness for the swap or even give me some technical advice; let’s just say that this was a failed attempt to reach out to someone I thought could help whom I would never refer anyone to. (maybe my expectations were too high). My background of this knowledge is that I have training in advanced electronics and theory. I am a Biomedical Equipment Technician. Also, I have installed over 100 car stereos.
Time to complete:
- 1-2days ------ 2-3 days (if you want the job to look extremely clean)
- Car panel removers
- Screwdriver (phillps)
- 10mm ratchet
- 8mm ratchet
- Wire cutters
- Wire stripers (VERY SHARP PAIR!)
- Extra Wire
- Electrical tape
- Sand Paper
- Navigation Head Unit - P/N: 39100-TS9-A62
- Cord Assy., HDMI-A – P/N: 39116-TK8-A01 (this is from a 2014-2015 Odyssey)
- Antenna Assy., GPS – P/N: 39835-TR3-A21
- HDMI/USB Cord Assy – P/N: 39155-T3R-A10 (will be found as an Acura part)
- One part number that I could not find is the actual container where the HDMI/USB/Cigarette lighter inputs are. When I bought the GPS unit the guy sent this as well.
So you have knowledge, parts, and now trust my information as valid. First things first make your self very comfortable with the schematics, wire diagrams and pinouts I post here. Try to really understand and know what every wire means, where each wire goes, the colors of each wire, what each wire might be carrying. One of the first things I did was map each wire/connector that may need to be cut, stripped, and re-connected to a separate connector that came with the navi unit I purchased. I purchased my navi unit from a totaled 2014 Si, and made sure that before receiving the unit that it was going to come with all stock connectors. If you do not have these connectors prepare yourself for an extremely difficult time (you will need a new dash harness P/N: 32117-TS9-A12) and honestly if I would’ve had to do this I wouldn’t have gave up.
Step 1) – Removal of old head unit
- Remove storage container just below the climate control switches (there are two screws located on the left and right inside of the container when it flips down) after removing these two screws it should just pop right off with the panel remover.
- There will be two screws to the left and right that are just below the climate control switches/knobs (they were hidden behind the storage container prior)
- Next there will be 2 8mm bolts located inside on the bottom side of the existing head unit. They may either be removed with an 8mm or screwdriver.
- The head unit now should just pop right off with the panel remover be sure not to apply too much pressure or you risk denting your dash and other interior panels
- Remove old connectors from climate control, hazard switch, and all from the backside of the old head unit. (now might be a better time if any to get that red JDM hazard switch you’ve been wanting!!!)
- Place old head unit in garbage, because that’s where it belongs
- You should now be looking at (1) connector for the hazard switch, (1) connector for the climate control, and (5) connectors for the stock head unit.
- Here they are listed from left to right: (your stock head unit)
- Main (24 pin)
- Sub/Amp (8 pin)
- HFL/AUX (20 pin)
- iMID/SH_BUS/GA_BUS (14 pin)
- AM/FM antenna (3 pin)
- Main (24 pin)
- I will call each by their respective pin count.
- The 24 pin harness is almost plug and play
- You will need to remove a metal pin and wire from the 24 pin harness that came with the Navi unit.
- I removed pin 11 just because that will be the one that we will be in need of using
- So pin 11 on the Navi unit is for the stereo controls located on the left of the steering wheel.
- We will need to tap into a wire on your iMID display.
- Remove your dash, this can be as easy or as hard as you make it but I figure that if you are that interested in doing this than you probably should know how to remove the dashboard.
- On your iMID display there should be a 32 pin harness.
- Remove this harness.
- Cut the wire from pin 23 and make sure you leave 1-1.5” of wire to work with. You could also add some length if need be.
- You will need to cut some wire long enough to be wired neatly from your iMID display to your new Navi unit.
- The first thing I did was cut, strip, twist, and tape this new long piece the the two ends of the original. So you basically are joining 3 wires together.
- The metal pin and wire that you removed from pin 11 of the 24 pin connector provided with your Navi unit will now be used. You will now route the new long piece of wire to the Navi unit and do your best of inserting the pin into the original 24 pin harness.
- You may have a trial and error here due to the pins not being the easiest thing to remove and insert.
- The 8 pin harness is plug and play
- The 20 pin harness:
- Remove your glove box, this can be done by squeezing the left and right tabs holding it in place
- There should be a small black box located up top when looking where your glove box is.
- There will be a harness located here as well, you will need to cut a 2” piece of wire
- You will then cut the wires located in pins (X) and (X) and join them together using the 2” piece of wire stated before.
- This is for your steering wheel Navi/HFT controls
- These steps are for the parking break switch.
- This is located at pin 11 of this connector.
- You will need another metal pin which can be taken from any connector not being used.
- This wire will be routed from pin 11 on the Navi unit to a green wire located under your e-brake. This should not require any splicing because the connector currently on the e-brake has room to just but a small amount of wire in. This may be done however you would like.
- The 14 pin connector is the more difficult portion of this, you will want to pay VERY VERY close attention and follow this STEP BY STEP.
- You will need to cut the 14 pin connector from your dash harness, I left about 1.5 inches of wire left on the connector just in case things got bad and didn’t work. So I will leave that up to you on whether you want to do this or not.
- After cutting this connector you will most likely want to add about 2 inches of length on each of these wires just to give yourself some space when making your “custom” wire harness by stripping, twisting and taping some on as well as striping the other end of the added length.
- C3 on the 14 pin is basically a ground for C1, C2, C7, and C8 --- the same goes for C4 on the 14 pin is a ground for C11 and C12. So you will know that these two groups WILL need to stay together.
- The configuration of the new harness is a 12 pin and a completely different layout and harness style. I will explain below.
- C2 is the ground for C3, C4, C9, and C10 --- and C2 is the ground for C1 and C7.
- You will need to match these wires to the pinouts provided and join them
- You will be left with 2 wires that are not used on the new connector. Hence 14 pin to a 12 pin connecter. I suggest either taping or crimping an electrical blocker on them.
- The 3 pin harness is plug and play
Step 4) - Now we will be discussing the new connectors/wires/harnesses you will be putting into your car.
- The HDMI Cord
- The USB Cord
- The GPS Antenna
- (1) The HDMI Cord:
- We will start with the cord from the Odyssey. (39116-TK8-A01)
- The tabs will need to be sanded down a little bit for fitment of the HDMI input.
- I would sand down little by little, test fitting every now and then into the tray from the 2014 Civic.
- When you achieve the perfect fit, you will insert it into the tray.
- Now we will use the cord from the Acura. (39155-T3R-A10)
- This cord will connect to the Odyssey part and be routed to the bad of your stereo. There is only one black input on the back of the Navi unit and this will be where the HDMI cord is inserted.
- (2) The USB cord(s):
- The Acura part (39155-T3R-A10) should have came with one cord with a grey end and one with a green end.
- They will correspond with the inputs on the back of the Navi unit.
- The green one will be routed to the 2014 Civic tray next to the HDMI input.
- The grey one is for the USB in your arm rest. This could be optional if you do feel you don’t need it. But it would bother me so much that there is USB input in there and it is not functional.
- Where this HDMI/USB tray sits, you will use the connector for the one that is routed from your iMID display to the center console. You will disconnect this and connect your new grey wire in the direction of the USB cable in the arm rest.
- (3) The GPS Antenna:
- This is a fairly simple task that I would recommend doing while the Dash is ripped apart.
- The antenna is going to be mounted underneath your dash.
- The antenna will come with the mounting plate but not the screws, so you will have to provide these.
- It is mounted up near the iMID display to the right a little. And the cord will get routed from here to the back of your new Navi unit. There is a small hole where you can see the old USB cable being routed through from the iMID unit. (I removed this USB cable completely.
I would like to thank Chris Sutton and College Hills Honda Service Center for their provided support and knowledge.
