18x9.5+20 with springs
Bradyn
Member
23
0
Hey I’m looking into getting some esr SR09 18x9.5 +20 offset, I have a set of 1.6” lowering springs. If the wheels would fit would I be able to use those springs or would that be to low
your rims will be well outside the fender area. I don't know what tire you're planning on using, but the first example is severely stretching tires
I mixed it up, it’s a +22 offset and the tires are pilot sport cup 2’s
So if you are ok with rims outside your fenders... I guess you’re ok. I don’t know up wide your tires are though. As you can see in this picture, this person is majorly stretching tires to get the tire inside the fender area.
