DIY 2012+ Civic Si - How to install Venair Silicone Coolant Hoses
Discussion in 'Engine DIY' started by squiggy, Jul 5, 2013.
  1. squiggy
    squiggy Cartographer
    10,922
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    Parts Needed
    600001121382-BL (BLUE), 600001121382-BK (BLACK), or 600001121382-RD (RED)
    Tools Needed
    Jack
    Jack Stand
    Wheel Chocks
    Various Pliers
    One Gallon Pitcher
    Funnel
    Distilled Water
    Safety Glasses
    Time Needed
    Approximately an hour
    1. Chock the rear wheels. Jack the front of the car up. Place your jack stands. You will need to get the car high enough in the air in order to fit your one gallon pitcher underneath.
    2. Remove the radiator cap. DO NOT DO THIS UNLESS THE CAR HAS COOLED DOWN!!! I RECOMMEND LETTING THE CAR SIT FOR AT LEAST AN HOUR AFTER DRIVING IT BEFORE DOING THIS. EVEN THEN, USE A RAG AND OPEN THE CAP SLOWLY.
    3. Locate the drain plug and drain coolant into the one gallon jug.
    The plug is approximately behind the vicinity of the red box.
    The coolant will drain nicely (for the most part) from the hole shown below. (top of picture is the front of the car)
    In order to reach the plug, you will need to need to pull down a bit of the bumper shroud. Jack point highlighted to help with bearings. (bottom of the picture is the front of the car)
    Turn the drain plug counter clockwise and let the coolant drain. This will take about five minutes. Cover the pitcher as you will be reusing the coolant and do not want to contaminate it.
    DO NOT forget to close the drain plug after the coolant has finished draining.
    4. Locate the upper radiator hose.
    5. Disconnect the intake flex hose between the throttle body and the air intake box from the air intake box side as shown below. This will make access to the rear hose clamp easier.
    6. Locate and remove the upper radiator hose clamp at the front of the engine bay next to the radiator cap. Accessibility is NOT easy. I recommend having a variety of pliers on hand. You may have to try a few out to try and find which ones will work best for each clamp.
    I used a giant pair of channel locks in order to reach around the small hose coming off the radiator. The trick to hose clamps is to be able to fully close your pliers in order to lock open the hose clamp itself. When this is achieved, you will be able to slide the hose clamp out of the way. Easier said than done most of the time unfortunately due to how tight and limited the access is in on this engine. Best bet is to open the clamp as much as possible and wiggle it away from the front of the hose. After that, just tug on the hose work it a little bit to get it off of the radiator. You can do this by grabbing the hose by the throttle body.
    Continued in the next post.
    mySIck, Nix, KennyGS and 3 others like this.
  2. squiggy
    10,922
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    7. Locate the rear hose clamp for the upper radiator hose. This one is easy to remove due to accessibility. I apparently didn't take a before picture, but here is a glimpse at an after picture just so you can see where the upper radiator hose connects to the engine.
    8. Install the new upper radiator hose. Pull the hoses out of the package and compare them so you grab the correct hose. Remove the hose clamps from the old hose and slide them on each end about 4". I recommend dipping your finger into the coolant and lubricating the inside of each end of the hose to make them slide on easier. Don't forget to reconnect the intake hose.
    Pic of the upper radiator hose installed.
    9. Locate the lower radiator hose. I started with the top hose clamp. It was accessible from the top of the engine bay. (you will need fairly small hands/forearms in order to do this) I was not completely accessible from this angle and had to work at it from underneath. Others may have better luck. That is the alternator on the left side of the picture.
    Upper hose clamp for the lower coolant hose as seen from underneath the car. (bottom of the picture is the front of the car)
    Warning: A fair amount of coolant WILL come out upon disconnection of this hose!!!
    10. Locate the lower hose clamp for the lower coolant hose. I had a tough time trying to get the right angle in order to get this hose clamp off. Come to find out later from the insider
    that you can pull off that smaller wire clamp closer to the radiator for quick release.
    11. Install the new lower radiator hose. Grab the remaining new hose. Remove the hose clamps from the old hose and slide them on each end about 4". I recommend dipping your finger into the coolant and lubricating the inside of each end of the hose to make them slide on easier.
    Installed pic from underneath.
    12. Using a funnel, slowly pour the coolant back into the radiator from where you removed the radiator cap. Top off the a bit approximating what you may have lost in the removal process with some distilled water. The amount will be insignificant enough to not throw off your mix.
    Do not forget to put the radiator cap back on!!!
    You are done!
    mySIck, Nix, KennyGS and 1 other person like this.
  3. squiggy
    10,922
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    Hose comparisons and final install pics.
    A big thanks to wesellcarparts!
  4. Arm0ged0n
    Arm0ged0n Well-Known Member
    1,574
    Corona, CA
    Vehicle Model:
    Honda Civic SI
    Body Style:
    Awesome job bro
  5. squiggy
    10,922
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    Thanks! :D
    This install was actually quite rough due to how tight everything is. Tore my hands and forearms up in the process. Also, got a face, ear, and mouth full of coolant. :bleh:
    Happy with the results, though!
    Dennis Rockholt likes this.
  6. webby
    • 2019 Toys For Tots
    webby Administrator
    50,263
    Wonderful diy. Looks great
  7. 808rallyred
    808rallyred Well-Known Member
    282
    Big Island,HI
    Vehicle Model:
    si
    Body Style:
    sedan
    Very nice DIY but I have a question do our cars have to be bleed or just refill and let idle?
  8. KennyGS
    KennyGS How may I help?
    11,644
    Keystone State
    Very well done! Great attention to detail, and very easy to follow. :clapping:
  9. squiggy
    10,922
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    I really do not know about the bleeding, but I have not had any problems since I have swapped the hoses.
  10. silver04v
    silver04v Well-Known Member
    390
    Most cars, if not all should be bled after opening the coolant system. This usually means, running the car without the radiator cap and have a funnel in it allowing air pockets to burp out. Hold 2-3k rpms for 10-15 secs then idle. And repeat until you have sufficient heat coming out your vents inside at idle. Then cap the radiator.
    Nix likes this.
  11. Nix
    Nix J├Âtunn Moderator
    10,765
    Lew-vul, KY
    Body Style:
    It's A Fast Pig!
    Great job as usual Squiggy!
  12. squiggy
    10,922
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    Not that I don't believe you silver04v, but can others chime in on this so I can add it to the steps if necessary? (and open mine up to do the same)
  13. silver04v
    390
    Yeah, do we have fsms here on the site that could be referenced? I'm a technician for Nissan and this is basically a mandatory thing for proper cooling bleeding. Usually a car will eventually burp itself but you can get one every now and then that won't burp itself through the reservoir and will keep a air pocket leading to no heat inside car and or overheating engine.
  14. squiggy
    10,922
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    I assume you mean service manual? Right now, there is only an online version that requires paid access.
  15. silver04v
    390
    I'll ask a buddy that works for honda what the procedure is.
  16. Dennis Rockholt
    Dennis Rockholt 9k Alll Day
    1,952
    Franklin, TN
    Vehicle Model:
    370Z Fairlady aka "Nismo"
    Body Style:
    So for my PRL Short ram intake they sent me a radiator hose similar to move the heated air away from the filter...I assume just follow these instructions to install that hose??
  17. 323
    323 Modifier
    5,252
    Chicago
    Vehicle Model:
    Body Style:
    Yup! I installed the same hose and intake
  18. Pauly99to17
    Pauly99to17 Well-Known Member
    9,170
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    Dyno Blue Pearl Sedan (FB2)
    Looks great! Great DIY.
  19. Dennis Rockholt
    1,952
    Franklin, TN
    Vehicle Model:
    Body Style:
    Yeah I just wasnt comfortable bleeding the system, but with this DIY all should be good now. I will probably install next weekend. I am assuming we may need a DIY for that intake!
  20. 323
    323 Modifier
    5,252
    Chicago
    Vehicle Model:
    Body Style:
    The PRL SRI is super easy to install, you should be fine
Share This Page
