2012 SI and 2012 CR-V share the same K24Z7 engine...
Dar-Dar
Mordorator
19,329
9,901
North NJ
I was wondering. Would it be possible to flash a 2012 CR-V Ecu with a Hondata Reflash or a future Flash Pro? The only difference I noticed between the two engines are the compression ratio. The CR-V has a lower compression ratio allowing it to have more torque, less hp/redline, than the 2012 Si's.
