2012 Tire Wear
  • I like being mr Nice guy:domokundance:
cupping is usually due to worn out struts/shocks. inside wear is mostly caused by too much toe out, causes the inside of the tire to scrub while driving which causes the wear. camber doesnt wear tires as much as people think, its because when you lower a car you do get more negative camber but your toe also toes out. we need your alignment sheet to help, anything else being said in here is a waste of time with out it. clearly your alignment is out or your shocks are done, at over 200k im sure your shocks could use replacement.
I am having this exact same issue, I just bought a 2012 Si HFP, came with the 18” wheels and bought a new 1100$ set of tires at the start of summer and by the end of summer they started making bad noise. Gonna be pretty disappointed if the tires are trash, but definitely gonna get my alignment looked into.
tire wear is cause often by jump starts and hard braking, so ya burn outs cause tire wear:shady:
