2013 Civic Si CT-e Testing -- With VitTuned Aftercooler!
Could you use a 3.5 in SRI with CT's or does it have to be a CAI?
8th gen users did the comptech with a SRI. (As long as you could get it to fit properly)
Reactions: 323
fujita example
Reactions: 323
Thanks, this is the route I'm going after seeing the power it can make
Speaking of E85 - Vit, is the fuel sending units on the 9th gens any different from the 8th gens?
(I.E. - are the contact points on the leveler arm board still open to the elements?)
I'm curious about the fuel sender. If I remember correctly the 8thgens had to be coated in something. Isthat not necessary in our 9thgens?
E85 on a bolt on build is pointless, it's 5-7hp which you will never feel. You will burn out your fuel level sender... when? Who knows... could be soon, could be one day. Its not a sealed unit, so it's exposed to corrosion.
Nevermind, found this. Guess it's like the 8thgens
