2015 Civic SI Ignition Coil Suggestions
dann_yo
New Member
4
0
Hey,
Recently my coils went bad and I wanted to know if any of you have had the same problem and what coils you used after. Do you have any recommendations on which ones to buy.
P.s.
Not force inducted
Car:
26,000 miles
Hey,
P.s.
Not force inducted
How many miles on the car? Ignition coils should last at least 100k.
For replacements stick with the oe denso units
Denso part# 673-2313
I’m also surprised to hear yours are bad. Are you out of warranty? I’ve had multiple cars go 150K+ on the originals. How did you determine they were bad?
Amazon product
View: https://www.amazon.com/Denso-673-2313-Direct-Ignition-Coil/dp/B01KGCPDQC
I bought my car crashed and it must have flipped, so the oil went up to the top of the motor burning the sparkplugs and evidently messing up the coils too. I’ve had to replace the sparkplugs twice already in less than 6 months. When its idling it jitters a bit, especially with the A/C on. And the scanner has said multiple times that all cylinders are misfiring.
Im with Webby on this, sounds like you should get the valves adjusted. Do this before buying new ignition coils imo.
