20mm spacers for flushed look?
snahfu
91
I have a 2014 civic lx. I replaced the steelies with 17 inch touring (EX-L) alloy wheels.
Will 20mm give me the flush look?
Most threads are about si so I am not sure if 20mm is right for me.
Also, my ride is at stock height and I plan on keeping it like that.
All 9th civics regardless of trim have the same +45 offset on whatever factory wheels they were equipped with. Stock ride height should also keep you from having any rubbing issues if you do run a 20mm spacer.
Thanks everyone!
Do you think its a silly look to get the wheels flushed without lowering? Having a hard time finding pictures of this setup.
Also, why do some people run 15mm in front and 20mm in back or vise versa.
