procivic
Vendor
This is a new throttle body upgrade kit we just started offering for 9th Gen Civic Si's. The throttle body used in this package is from a Honda J37 motor, and features a huge 80mm inlet that tapers to 70mm at the throttle plate. We use very high quality AN fittings as well. The bolts we use are also longer than normally supplied with this kind of upgrade. The reason for this is there is not a ton of thread engagement after putting on the spacer and both gaskets...so these longer bolts solve that issue.
The installation is super easy and, with the supplied adapter, bolts right up to your stock manifold or an aftermarket manifold. The throttle body adapter works as a spacer to help performance even more, and we also include thermal gaskets as well. This throttle body performs especially well when paired with a port matched intake manifold.
We're offering a special forum discount of $30 off on this product. They are IN STOCK and ready to ship! Just use the discount code "9thcivic_oem_tb" when ordering.
Ordering/product link: Honda Civic Honda of Japan OEM Big Bore Throttle Body Upgrade Kit
Keep in mind when looking at the above pictures, the 9th Gen Si version of this kit includes slightly different hardware (the pictures are of the 8th Gen Si version).
- Increases horsepower and torque by optimizing airflow to your engine.
- Gains of up to 10+ hp, naturally aspirated (more on turbocharged and supercharged vehicles).
- Huge 80mm inlet that tapers down to 70mm at the throttle plate.
- An easy "plug and play" bolt-on installation. Includes installation sheet with torque specs as well.
- Throttle body is made by Honda, and includes all DBW (Drive by Wire) circuitry.
- Features high quality bolts and AN fittings.
- Compatible with all factory sensors and emissions equipment.
- Includes special throttle body spacer and thermal gaskets to help maximize power output.
