Adjustable shocks for 9th Gen SI's
Discussion in 'Suspension And Brakes' started by Stan Dorobek, Aug 1, 2016.
  1. Stan Dorobek
    Stan Dorobek Active Member
    6
    Hi everyone. I do a decent amount of autocrossing and am looking for some adjustable shocks. I know Koni Makes inserts for the fronts if you cut up your struts and I'd rather stay away from doing that. Does anyone else know of adjustable shocks made for 9th gen Civics?
  2. webby
    • 2018 Toys For Tots
    webby Administrator
    49,532
    truhart is the only shock I can think of that is actually a direct swap. Koni needs fab work like you mentioned above.
    ron v likes this.
  3. Flightmaster127
    • Supporting Member
    Flightmaster127 Supporting Member
    3,460
    Delaware
    Vehicle Model:
    Body Style:
    Are you looking for just shocks for stock or street class limitations?
  4. rac081
    rac081 Well-Known Member
    3
    Any update on this. Looking for adjustable shocks for stock springs to stay legal in stock/street class for auto X
  5. webby
    webby Administrator
    49,532
    Talk to redshift about their koni setup, but it requires fab work.
    https://store.redshiftmotorsports.com/aboutus.asp
  6. Flightmaster127
    • Supporting Member
    3,460
    Delaware
    Vehicle Model:
    Body Style:
    I don’t know of anything personally but I had decent results with just the stock suspension in hstreet. What other mods do you have done?
  7. rac081
    3
    I've got Hankook Ventus R-S4 tires, Hawk pads frt and rear, AFE drop in air filter. Planning on doing the rear sway bar next.
  8. Flightmaster127
    • Supporting Member
    3,460
    Delaware
    Vehicle Model:
    Body Style:
    The rear sway is going to help you tremendously. It really helps the car rotate.
Share This Page
