Bruce Bartlow
Late apex everything
- 1,595
- 861
- Vehicle Model
- I am nowhere near the Ring, otherwise the C8 would be a tempting test drive. Outside the Ring, a CTR checks a lot of boxes
____________________________I've been changing the OEM fluid every other oil change so every 15000 miles. I'll send a sample to Blackstone next time.
Given that there are no outside contaminants in MTF you should be able to go 2 years without changing it .... bare minimum.
About Engine Oil. If you want to know it's safe to going beyond 3,000 - 7,000 miles (i.e., "extended drain intervals") you'll want to know the lubricant's total base number ("TBN") -- the oil's remaining ability to neutralize acids. Very very important number. It's an extra $10.00 to get TBN tested at Blackstone. So it's $25.00 (basic Blackstone test) + $10.00 for Blackstone TBN = $35.00, although discounts are available for 6-packs. OR you can consider another company, Oil Analyzers Inc. Oil Analyzers includes the TBN test at no extra charge, and even includes other useful tests like Oxidation and Nitration at no additional charge. Last i looked the whole enchilada at Oil Analyzers was $22.95 instead of Blackstone's $35.
Worthwhile tidbit: An oil begins to darken with as little as 2% oxidation. But there's a problem with that ----- we get faked out. The oil looks dirty so we think it is dirty. Nothing could be farther from the truth. Unless there are other reasons to change your oil (spectrograph readings, TBN, water, glycol) your oil is still clean and doing its job until it has reached 50% oxidation. In other words, the oil can appear dirty even when there's nothing wrong with it.
