MissE
Ok, so I just had a remote car starter installed in my Si by my dealership (due to our delightfully freezing winters on the Canadian East coast). I'm just wondering, does anyone else on here have one?
I was expecting your typical system that I have seen in family and friends cars (where you turn the car off however you normally would and it's good to go), but in mine there is a 4 step process you need to follow within a 20 second window everytime you go to turn off the car if you want the remote starter to be "engaged" (ie: usable). You need to shift into neutral, pull the e-brake, release the regular brake, and then push a button on the keychain remote. If you do any of these steps out of order or take longer than 20 seconds then the remote starter won't engage. Then the car stays running until you get out of it (even though you've removed the key from the ignition) and it turns the car off once you're outside the car and push the doorlock button. Also, when the starter is "engaged" it seems to render the buttons to lock/unlock the doors on the actual car key useless.
I've never used a car starter in a standard car before now, but does all of this sound normal? Because to me it seems rediculously complex and if my dealership had bothered to tell me all of this in advance I'm not sure I would have bothered with it.
