So I could use some help before I spend some money. My hatchy is running high idle and sometimes chases from 1400-1900 then settles after about a minute at normal operating temps. When it settles the idle is usually about 1200. Sometimes it settles at 1050.
It’s a b18c with a Skunk2 Im and Skunk2 type r throttle body. Hondata thermal IM gasket. My TB doesn’t have a fitv so that’s off the list.
What I’ve done so far was cleaned the IACV, checked for vacuum leaks around the IM and injectors, tried to reset the idle, cleaned the tb even though it’s practically brand new. Messed with the throttle plate and adjustment screw and have played with the idle adjustment screw. I know ohms for a IACV should be around 8-15 so my next step should probably be hitting that with my meter. Also to hit all vacuum hoses and ends for leaks.
My first thought is a bad IACV. If not I’m fearing it’s something in the head components. I know there’s a lot of Honda heads lurkin so any thoughts at all are appreciated.
Thanks for reading.
Thanks for reading.
