Ron Flood
one part at a time.....
front lip... originally only going to do the front since everyone i have ever talked to or heard about had issues with warped side skirts.....
yes they came warped... had to take a heat gun to them to for the most part straightened them out....
sideskirts are a tight fit, stretches them out quite well, very minimal warpage, actually the whole kit is very well fitted... i really wouldnt recommend this kits for lowered cars, since it lowers your front and rear corners about 1.5".. but id like to point out the sideskirts are about the same height as your jack points, its only an optical illusion that the sideskirts are actually lower.... and also like to point out the front and rear lips in the center lay flat to your factory under carriage plastic...
i have an N1 style aftermarket exhaust and it fits just fine with or without the rear lip... hence why its good to lay flat in the middle of the rear lip....
i can say in all honesty, it wasnt too bad to install, altho i didnt have a helper, i would recommend you have a helper.. hahaha
