- 57,234
- 24,362
it's a direct plug and play unit...isn't it? No additional wiring/splicing?
Thanks. I have been considering the Eibach Pro-kit or Sport line coil overs. I'd like to have a modest drop to improve performance, but nothing ridiculous.You're car is looking sweet sir. Usually I dislike painted brake calipers, but the color contrast you created by doing them yellow makes it stand out. I really like the look of them a lot. Are you planning on lowering it in the future?
Correct. The resistors are also removable...attached with a quick-connect. I figure I could fashion some shielding from aluminum which might correct the problem.it's a direct plug and play unit...isn't it? No additional wiring/splicing?
For the record, the pin striping is not plasti-dip.Time attack wheel style with plasti! You saw it here first folks.
Can you find red plasti in stores around you, or you're buying it and having it shipped?
