Broadway Mirror
Discussion in 'Inside and Out' started by Pauly99to17, Oct 11, 2013.
  1. Pauly99to17
    Pauly99to17 Well-Known Member
    9,160
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    Dyno Blue Pearl Sedan (FB2)
  2. webby
    • 2018 Toys For Tots
    webby Administrator
    48,701
  3. mpheng
    mpheng Well-Known Member
    121
    Calgary, Alberta
    Vehicle Model:
    Civic
    Body Style:
    I have the broadway 270mm convex mirror, it works great. Just a little harder telling distance from the mirror while backing up but it helps see a lot more. Really helps me see the blind spot from the rear right side.
    Yes it clamps right over the existing mirror and I have no problem with it getting in the way of the sun visors.
    Pauly99to17 likes this.
  4. WhereIsBurkey
    WhereIsBurkey Well-Known Member
    352
    Soledad, Ca
    Vehicle Model:
    Honda Si
    Body Style:
    get one!! its probably one of the first Mods i did on my car.
    an trust me youll see everything. lol theres a big difference
  5. Flippercon
    Flippercon Well-Known Member
    1,697
    Virginia Beach, VA
    Vehicle Model:
    Body Style:
    I got a 300mm convex and it just fits between the visors at the angle it sits.
  6. Pauly99to17
    9,160
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    Thanks for input. It seems like there may be a choice if I am understanding correctly.
    Convex or straight. Most going with convex. ???
  7. Flippercon
    1,697
    Virginia Beach, VA
    Vehicle Model:
    Body Style:
    I got convex since te view is wider. In my coupe I can see the edges of both windows on my doors.
    Monk and Pauly99to17 like this.
  8. FB2Chris
    FB2Chris Well-Known Member
    2,804
    I used to have the 400mm broadway mirror. It clamped right onto the stock mirror and I never had any issues with the sun visors down. You'll be fine with a 270mm.
  9. ADExternal
    ADExternal Lvl: 99 Modifier
    1,917
    Houston, Tx
    Vehicle Model:
    Civic Ex
    Body Style:
    I use a 300mm straight since you cant really see out behind the B pillar anyways. But it gives the entire rear window without moving your head.
  10. 91alexm
    91alexm Well-Known Member
    74
    Bay Area, CA
    Vehicle Model:
    LX, R18
    Body Style:
    Yeah you should deff. buy. I've had the 300mm straight before I even had my civic. Helps you see a lot more and that's at a good price too.
  11. KKaWing
    KKaWing Well-Known Member
    126
    With a 270mm convex, I keep wishing I could angle out the wing mirrors out more so the 3 mirrors could make a continuous "view" if you get my meaning. Note that I drive a Versa :p
  12. MrK24
    MrK24 Well-Known Member
    207
    Paris, TX
    Vehicle Model:
    SI
    Body Style:
    I have the 300mm blue tinted flat Broadway. I recommend the flat one because alot of people say that the convex one sometimes gives them a headache. Also decided on the blue tint cause it drowns out annoying bright *** HIDs behind me. One of my earliest mods and I've never regretted it.
  13. Pauly99to17
    9,160
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    Hmmmmm, :think: Blue eh?
    Thanks for input fellas!
    MrK24 likes this.
  14. Beeshabo
    Beeshabo Well-Known Member
    169
    I think the "convex" is better, you can see out of your rear windows and not just your rear windshield, it does take some getting used to though.
    Pauly99to17 and Flippercon like this.
  15. Flippercon
    1,697
    Virginia Beach, VA
    Vehicle Model:
    Body Style:
    I agree , have not got a headache from it either.
  16. Beeshabo
    169
    Yeah, I didn't get a headache at all, my eyes just got a little funky the first few times I looked at it...but now it feels completely natural and I don't think I could revert back to the stock mirror.
    Flippercon likes this.
  17. Monk
    Monk Well-Known Member
    4,218
    SW Virginia
    Vehicle Model:
    2012 Civic EX
    Body Style:
    Coupe FG3:ASM
    Convex..... You're only suppose to look to your rear for split sec's at a time.... not enough time to give you a headache.
    I don't see the point in a straight RV mirror, it's the area from your peripheral vision all the way to the rear view mirror that's the blind spot.
    That's where you need to see, the longer you take your eyes off the front the more danger you're in.
  18. Beeshabo
    169
    I don't think they're getting headaches from "staring" at the mirror, even glancing at it (at first) almost makes your eyes want to cross, at least that's how I felt, so I can see how it would give you a headache just from glancing at it, especially if you glance at it several times a minute, which is what you're supposed to do. Some can adjust to it and some can't. Took me about 10 minutes (of normal driving) to adjust to it.
  19. Pauly99to17
    9,160
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    Dam. Now I'm confused about which one to take again. Lol
  20. Beeshabo
    169
    If you want just a wide view, go with a flat one, but if you want a wider-ER view then go with the convex one. It really helps, I can see outside my rear passenger window with it, it's awesome. Just remember, the convex mirror makes it a little harder to judge just how close you are to things when you're backing up.
Share This Page
