Clutch issue
07TLX
Supporting Member
VIP Member
4,437
1,596
Somewhere in SEPA
Pontiac
G8 GT
Not on a 9th gen but my 8th gen LX....
116kish on the ticker, stock clutch and flywheel and I have noticed in the last week or so that my clutch pedal is grabbing almost at the top. I am thinking clutch is going bad but I really don't have any symptoms other than that the pedal so I am bit confused on what else it could..... Help please?????
It doesn't slip while driving, it's just the clutch pedal engament, it used to grab down near the floor and now it's grabbing near the top of the pedal....
not sure if you've had a solution yet; this can be indicative of clutch wear. would usually be accompanied by heavier clutch pedal. good way to test this would be get out on a highway by yourself and get to around 4k rpm or wherever peak torque is in your car while in top gear and briefly plant the accelerator without touching the clutch, if there's any slipping this should confirm the issue for you
