Clutch Noise
Discussion in 'Mechanical Problems & Technical Chat' started by TeeEyeVany, Dec 13, 2012.
  1. TeeEyeVany
    TeeEyeVany Well-Known Member
    419
    Paradise, Newfoundland, Canada
    Vehicle Model:
    Civic Si w/Navi
    Body Style:
    So I've been experiencing some clutch noise in my 2012 Civic SI for the past month or so. It happens when I'm starting from a dead stop. It's like a grinding type of niose once the clutch reaches the friction point. I had it in the dealer today for an oil change and to replace something with the driver door due to a recall and I got them to take a look at it.
    They said it could be springs or something inside the clutch and they'd have to order in the part. They also said that it should be covered under warranty however, if they get in there and see that there is "a lot of scorch marks" and "signs of abuse" that I'd be on the hook for the repair.
    Just thought I'd share it here.
    Note I've had my car for 15 months and it has 31,100 kms (~19,300 miles)
  2. webby
    • 2018 Toys For Tots
    webby Administrator
    49,134
    Are you worried about what they may find? No clue how hard you've been on the car
  3. TeeEyeVany
    419
    Vehicle Model:
    Civic Si w/Navi
    Body Style:
    I haven't been hard on the car at all...I've been driving standard for almost 6 years and haven't had any problems with any of my other cars..I don't ride the clutch or anything like that
    Some days it seems to be worse than others...like I drove it from the house to the dealer this morning and I only heard it once...drove it then from the dealer to work and didn't hear it at all....some days I don't hear it while other days its happens almost every time I stop and start
  4. Kevin Kugelman
    Kevin Kugelman Active Member
    1
    I found this post while searching, I have 27k miles on mine and I'm experiencing the same thing, glad I'm not alone. It'every so often from a dead stop. I can tell you that I've been very nice to my car as this is the first new car I've ever owned.
    KennyGS, webby and TeeEyeVany like this.
  5. TeeEyeVany
    419
    Vehicle Model:
    Civic Si w/Navi
    Body Style:
    Glad to hear I'm not the only one.....The guys at the dealer have to order in the part and of course it's on backorder so he said that it won't come in until almost the end of January....He said that it is fine to drive but if the noise gets any worse or begins to happen more to try and cut down on the usage until its fixed
  6. Flippercon
    Flippercon Well-Known Member
    1,697
    Virginia Beach, VA
    Vehicle Model:
    Body Style:
    Wow cut down on the usage until it gets fixed???? Thats a load of crap. I would expect them to at least offer a loaner while the part is on back order if is that much of a concern.
  7. Nomar06
    Nomar06 Super Moderator
    7,400
    Charlotte, NC
    Vehicle Model:
    Fiesta ST (FiST)
    Body Style:
    hatch
    Yeah...that's bs. End of January????
    Flippercon likes this.
  8. mno86
    mno86 Well-Known Member
    83
    Minneapolis, MN
    Vehicle Model:
    Honda Civic Si
    Body Style:
    Can't say I'm surprised. At around 40,000 miles in my 2006 Si, the clutch make a long squeaking noise every time it was depressed, like a long wheeze sound. I think those models actually had a TSB related to it.
    My 2012 Si's clutches don't do that, but they do click pretty audibly when they're pressed.
    You'd think they'd have figured out how to make this not happen. Maybe that's why they're slowly eliminating a stick shift from their entire line up. I noticed you can now only purchase a stick in the Accord coupe for 2013 with an LX-S (and only in black) or the top of the line V6 (in limited colors).
  9. TeeEyeVany
    419
    Vehicle Model:
    Civic Si w/Navi
    Body Style:
    The guy said that it isn't a concern or anything but it do need to be fixed....I made sure that when I bring it back they won't say that the damage was caused by me driving it
    My mom had an 07 accord and the clutch was constantly squeaking in it (even after they fixed it)
  10. KennyGS
    KennyGS How may I help?
    11,644
    Keystone State
    I'm curious to see what this ends up being for you. Good luck.
  11. TeeEyeVany
    419
    Vehicle Model:
    Civic Si w/Navi
    Body Style:
    Thanks man....It seems to get worse when it is wet...it was sunny the other day and i barely heard it at all but it is snowing here tonight and it heard it a few times earlier when I drove
  12. brown_bear
    brown_bear Well-Known Member
    1,003
    Reston, Virginia
    Vehicle Model:
    Body Style:
    im experiencing similar sounds, mine sounds like the buses when they brake, like a creaking/grinding/squealing noise. first noticed it this week when is was creeping fwd and happens mostly in 1st gear too...never had a issue with my 07 fa5 and i racked up 95k on it before it got totaled
  13. TeeEyeVany
    419
    Vehicle Model:
    Civic Si w/Navi
    Body Style:
    Well my car is suppose to go into the dealer on Jan 10 to get it done as long as the parts are in...hopefully it'll fix the problem
    It's nice to know others are experiencing the same problem
  14. brown_bear
    1,003
    Reston, Virginia
    Vehicle Model:
    Body Style:
    I hope its covered under warranty because i can't afford it. I dont abuse my car either, i do drive spirited at times but not crazy like a racecar.
  15. TeeEyeVany
    419
    Vehicle Model:
    Civic Si w/Navi
    Body Style:
    Yea...the guy at the dealer said it should be covered and that they need to tell people that it might not be just incase
    The way I look at it is I've been driving standard since I've been driving (6 years) so it's not like I don't know what I'm doing
  16. brown_bear
    1,003
    Reston, Virginia
    Vehicle Model:
    Body Style:
    i've got about the same under my belt. You would think that clutch can handle spirited driving since its a SI but i guess not..
  17. TeeEyeVany
    419
    Vehicle Model:
    Civic Si w/Navi
    Body Style:
    Yea really though...I just hope it gets covered cause I don't want to spend the money on that right now...I obviously will if I have to buy I'd rather not
  18. TeeEyeVany
    419
    Vehicle Model:
    Civic Si w/Navi
    Body Style:
    So just to update everybody...I put my car in the garage today and they replaced the clutch, pressure plate and release bearing. All was covered under warranty!
    webby, KennyGS and Dragos like this.
  19. Dragos
    Dragos Well-Known Member
    799
    Ottawa, Ontario, Canada
    Vehicle Model:
    Si
    Body Style:
    4 Door Sedan
    Sounds like you just got a random defect. Did they tell you what was broken?
  20. KennyGS
    11,644
    Keystone State
    Good for you! :woot:
Share This Page
