Completely Lost the Display on the iMid! HELP!!!
Discussion in 'Mechanical Problems & Technical Chat' started by squiggy, Apr 15, 2013.
  1. squiggy
    • 2018 Toys For Tots
    squiggy Cartographer
    10,717
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    I was working on installing some speakers and the battery died on me. Can probably be attributed to music playing, headlights on due to always leaving them on auto (stupid me. I did this once before...), driver's door and trunk open, and the car was never running.
    Anyway, I saw a warning (power steering I think) flash up on the iMid as I was checking preouts on the head unit and then the battery died about 15-30 seconds later. Jumped it. Started no problem, but no display on the iMid...
    So, who knows what fuse to check for the iMid?
    Also, does anybody think that unhooking the battery for 10-15 minutes to reset the ecu might do the trick?
  2. CivicCanuck
    CivicCanuck Well-Known Member
    782
    North
    Vehicle Model:
    Civic
    I would try that and see what happens.... could be what the problem is. Unless you shorted out something checking pins, but I doubt it, if you were listening to music, with lights and other loads on, sounds like the battery voltage was low enough for it to kill everything. Charge up the battery and reconnect the wires.
  3. Dragos
    Dragos Well-Known Member
    799
    Ottawa, Ontario, Canada
    Vehicle Model:
    Si
    Body Style:
    4 Door Sedan
    That's a tough one, for me at least. Looked at the manual page 318 the fuses description and there is nothing about imid or display in general.
    Here are all of them listed, sorry for the bad formatting :(
    Engine compartment
    ■ Circuit protected and fuse rating
    Circuit Protected Amps
    1
    EPS 70 A
    ABS/VSA Motor 30 A
    ABS/VSA FSR 30 A
    Main Fuse 100 A
    2
    IG Main 50 A
    Fuse Box Main 60 A
    Fuse Box Main 2 60 A
    Headlight Main 30 A
    Rear Defogger 30 A
    Blower 40 A
    Sub Fan Motor 20 A
    Main Fan Motor 20 A
    3 − −
    4 Left Headlight Low Beam 10 A
    5 Starter DIAG, ST MG 7.5 A
    6 Right Headlight Low Beam 10 A
    7 − −
    8 − −
    9 − −
    10 − −
    11 Oil Level 7.5 A
    12 Fog Lights* (20 A)
    13 Driver’s Power Seat Sliding* (20 A)
    14 Hazard 10 A
    15 FI Sub 15 A
    16 IG Coil 15 A
    17 Stop 15 A
    18 Horn 10 A
    19 Premium Amp* (20 A)
    20 INJ (15 A)
    21 IGP 15 A
    22 DBW 15 A
    23 H/L LO 20 A
    24
    Driver’s Power Seat
    Reclining* (20 A)
    25 MG Clutch 7.5 A
    26 − −
    27 SMALL 20 A
    28 Interior Lights 7.5 A
    29 Backup 10 A
    Interior
    1 − −
    2 ACG 15 A
    3 SRS 10 A
    4 Fuel Pump 15 A
    5 Meter 7.5 A
    6 Power Window 7.5 A
    7 VB SOL* (15 A)
    8 Door Lock Motor 2 (Unlock) 15 A
    9 Door Lock Motor 1 (Unlock) 15 A
    10 − −
    11 Moonroof* (20 A)
    12
    Accessory Power Socket
    (Center Console)* (15 A)
    13 − −
    14 Seat Heaters* (15 A)
    15
    Driver’s Door Lock Motor
    (Unlock)* (10 A)
    16 − −
    17 − −
    18 − −
    19 ACC 7.5 A
    20 ACC Key Lock 7.5 A
    21 Daytime Running Lights 7.5 A
    22 HAC 7.5 A
    23 − −
    24 ABS/VSA 7.5 A
    25 − −
    26 − −
    27
    (Front)
    15 A
    28 Washer 15 A
    29 ODS 7.5 A
    30
    (Lock)* (10 A)
    31 − −
    32 Door Lock Motor 2 (Lock) 15 A
    33 Door Lock Motor 1 (Lock) 15 A
    34 Small Lights 7.5 A
    35 Illumination 7.5 A
    36 − −
    37 − −
    38 Left Headlight High Beam 10 A
    39 Right Headlight High Beam 10 A
    40 TPMS* (7.5 A)
    41 Door Lock 20 A
    42 Driver’s Power Window 20 A
    43
    Rear Passenger’s Side
    Power Window
    (20 A)
    44
    Front Passenger’s Side
    Power Window
    20 A
    45
    Rear Driver’s Side Power
    Window
    (20 A)
    46 Wiper 30 A
  4. squiggy
    10,717
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
  5. AlienPrime
    AlienPrime Well-Known Member
    3,058
    Sudbury, Ontario, Canada
    Vehicle Model:
    Civic Si HFP
    Body Style:
    2 door Coupe
    yeah definetely not a fuse... bring her in to Honda and keep us posted :)
    Bet it's the screen inverter :)
  6. squiggy
    10,717
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
  7. Pauly99to17
    Pauly99to17 Well-Known Member
    9,159
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    Dyno Blue Pearl Sedan (FB2)
    Could the loud music have caused a vibration making one of your newly installed pins come loose? Hmmmmm? These pins are for the reverse camera though....would it even matter if one did? I would guess that only your reverse camera would to work, not the entire Imid screen. .????
    AlienPrime likes this.
  8. squiggy
    10,717
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    Reverse camera goes into the Head Unit. Not the iMid.
  9. Pauly99to17
    9,159
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    Oh wow..... I didn't even know that was possible. Everyone i have seen add the reverse camera has it hooked up to te Imid. You must be one of the first... .???
  10. squiggy
    10,717
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    It is a Pioneer with a dedicated input.
  11. Pauly99to17
    9,159
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    Oh...okay. Makes sense now.
  12. AlienPrime
    3,058
    Vehicle Model:
    Civic Si HFP
    Body Style:
    2 door Coupe
    lol bring him to hondaaa :p
  13. CollegeHillsHonda
    • Vendor
    CollegeHillsHonda Vendor
    469
    Wooster, OH
    Check underdash fuse A19.
  14. AlienPrime
    3,058
    Vehicle Model:
    Civic Si HFP
    Body Style:
    2 door Coupe
    but that's all accessories.. not just iMiD :(
  15. CollegeHillsHonda
    • Vendor
    469
    Wooster, OH
    Yep. Looked at the schematic and it says the iMid runs off A19 for premium audio.
  16. squiggy
    10,717
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    That doesn't make sense, though. I never lost audio.
    On the other hand, I went out to lunch and the iMid is working again. :confuzzled:
  17. jasonandre
    jasonandre Deal with it
    2,607
    Alexandria, VA
    Time for a battery terminal cleaning and tightening.
  18. squiggy
    10,717
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    Everything is still clean and tight. Six months old and only about 5000 miles.
  19. jasonandre
    2,607
    Alexandria, VA
    Insert "that's what she said" joke here.
    Pauly99to17 and Flippercon like this.
  20. AlienPrime
    3,058
    Vehicle Model:
    Civic Si HFP
    Body Style:
    2 door Coupe
    alright well try swapping fuses... otherwise.. idk if fuse 19 was blown all accessories would be malfunctioning :(
Share This Page
