fritz
So I installed plug and play headlights and had an issue with the driver side drl/high beam. Long story short I first made sure I was getting current to the plug and my tester showed it was good so then I pulled the bulb and discovered a broken weld on the bulb causing it to lose connection when the car vibrates. So I got a new bulb and installed it and it still didnt work. New bulb is 100w not 55w first off so I messed up there, but now there is no current coming out of the factory side of the wiring harness as well. I checked fuses in the engine compartment for hi/lo beams (I believe they were 2 and 5 or something) and I checked the fuse inside (21).
Does anyone with some more knowledge than me might have an idea of my issue?
