DIY Full-Race 3" Downpipe and Catback Exhaust System
Discussion in 'Intake & Exhaust DIY' started by squiggy, Jul 30, 2013.
  1. Tim Abadie
    Tim Abadie Well-Known Member
    80
    Jupiter, FL
    Vehicle Model:
    FB6
    One more question, would it be best to put the RMM in before or after DP/exhaust or does it not matter?
  2. squiggy
    • 2018 Toys For Tots
    squiggy Cartographer
    10,735
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    Doing the RMM at the same time may help with the wiggle room needed for getting the old DP out and the new one in.
  3. Tim Abadie
    80
    Jupiter, FL
    Vehicle Model:
    FB6
    Hey Guys, after the install I notice a slight rattle sometimes while shifting or going over bumps, and the sound was coming from the right rear tire. I took a look and noticed the pipe barely clears the right rear control arm. I'm sure this is where the rattle comes from. Any suggestions on how to get a little more clearance? I only need a 1/4 inch at most. Should I buy a new, stiffer hanger?
  4. webby
    webby Administrator
    48,705
    r18-power likes this.
  5. FreeSamples
    FreeSamples Well-Known Member
    347
    I followed this diy and its great. The part I'm stuck on is removing the second o2 sensor. Its on there very tight and it ended up stripping. I stopped before it got worse but if i keep going it's definitely going to strip. I'm installing a skunk2 downpipe. Do I need to have it plugged in? Would disabling the secondary o2 sensor work? If not I might have to buy a different secondary o2 sensor to plug it in.
  6. dpetro1
    dpetro1 Well-Known Member
    376
    Catonsville, MD
    Are you using an o2 socket? If the downpipe is off the car you can hit it with an impact.
  7. FreeSamples
    347
    I did use a o2 socket. I ended up just buying a denso o2 sensor and leaving the oem one in the oem down pipe.
  8. NoLimit13si
    NoLimit13si New Member
    1
    Great dyi! It really provided lots of help and detail. After going through your guide i had a better understanding as to what i needed to do to easily instal my k-tuned downpipe. Thanks again!
    bootyluvr and squiggy like this.
  9. bootyluvr
    • Supporting Member
    bootyluvr Supporting Member
    16,446
    Baltimore, MD
    Vehicle Model:
    2015 Honda Accord EX-L V6
    I still can't believe it's been 5 years since I uploaded these videos! :omg:
  10. squiggy
    10,735
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    Too bad my car is a 2012...
  11. bootyluvr
    • Supporting Member
    16,446
    Baltimore, MD
    Vehicle Model:
    Whoops.. I'll edit. I was going by the Dragon List :P
    Edit: Changed
  12. Ralph619
    Ralph619 Well-Known Member
    9
    Just installed my downpipe on new years eve this DYI hella helped me out took about 8 hrs had to keep coming out for tools lol got the motor mount in aswell .I get some weird idling tho when in neutral if any 1 gots any info on that fix .Thanks for the install guide .
    Sarcras likes this.
  13. webby
    webby Administrator
    48,705
    your car is not going to run properly without getting hondata flashpro and a tune on aftermarket downpipes. This is quoted from the diy above
  14. ron v
    • Supporting Member
    ron v Throbinson Crusoe
    3,160
    Escondido
    Vehicle Model:
    Hot fuego
    Body Style:
    Coupe and hatch
    Tunes an absolute must. I had to run my fbo setup for a day with no tune and the car just stalled and misfired. I ended just getting it towed home so I could upload my final cal from vit.
    Sarcras and webby like this.
Share This Page
