Sold HFP springs
Discussion in 'Sold' started by dwmilton, Jan 10, 2018.
Thread Status:
Not open for further replies.
  1. dwmilton
    dwmilton Well-Known Member
    66
    El Paso, TX
    Vehicle Model:
    Si
    Body Style:
    Wanting a set of 9th gen HFP lowering springs. The struts & shocks aren't needed. Shipping will be to 79932.
  2. dwmilton
    66
    El Paso, TX
    Vehicle Model:
    Si
    Body Style:
    Bump...no one have a set of HFPs sitting around, they’ve moved on from?
  3. webby
    • 2017 Toys For Tots
    webby Administrator
    47,791
    Just curious, did you find a set of hfp struts/shocks missing the springs and now you need springs?
  4. dwmilton
    66
    El Paso, TX
    Vehicle Model:
    Si
    Body Style:
    No sir, I have a 2014 Si sedan, so the front struts aren’t compatible. I just want the drop/ride/handling balance the HFP springs would offer. Something between OE and my current Swift Spec-R springs.
  5. webby
    webby Administrator
    47,791
    Swift r springs are almost the same drop. I can’t imagine you’d actually notice much even if you found some hfp springs by themselves. Are you on oem struts/shocks? You may want to look at the truharts. They’re around ~$250ish for all 4. That would prob actually get you closer to the hfp suspension feel with your current springs.
  6. dwmilton
    66
    El Paso, TX
    Vehicle Model:
    Si
    Body Style:
    Yes, I’m on the OE struts/shocks. Chris at Redshift said something similar. I guess it just seemed counter intuitive to me. I likely don’t properly understand how the shock valving works with/against spring rates. My thoughts were that the struts didn’t change, so the Swift springs caused me to feel every pebble/ripple in the road. From there, I figured the OE struts and springs were both taller and softer; with the HFP parts splitting the difference between OE & Swift.
  7. Tak
    Tak Well-Known Member
    555
    New York City
    Vehicle Model:
    LX
    Body Style:
    Sedan (FB2)
    Hello
    I can sell you the whole set of HFP suspension lol
  8. dwmilton
    66
    El Paso, TX
    Vehicle Model:
    Si
    Body Style:
    Thanks Tak, what price would you be asking, shipped to 79932?
    With other input I’ve gotten above and elsewhere, it seems I have inexpensive alternatives, that’d net the same results.
Thread Status:
Share This Page
