Installed Eagle Eye LED Tail Lights for '13 Coupe!
Discussion in 'Navigation, Security Systems, & Electrical' started by Hillstones, May 31, 2014.
  1. Hillstones
    Hillstones Well-Known Member
    204
    Valencia, CA
    Vehicle Model:
    Maxima Platinum
    Body Style:
    I changed the title and the first post because I recently purchased and installed the Eagle Eye LED tail lights for the '13 coupe. Found them on eBay for $189. The seller was imotorsportoutlet. Other sellers were as high as $269 for the same lights. Here is the link, although it will likely expire and renew with more available.
    http://www.ebay.com/itm/400666473757
    I will add another post with install photos. These lights are great quality, as I had a pair of Eagle Eye tail lights for my old '03 Accord coupe. However, these are a much better fit than the Accord lights. I am very happy with them, and the LED tail lights now match my OEM LED high step light in the rear spoiler.
  2. innoAR
    innoAR Well-Known Member
    259
    orange county
    Vehicle Model:
    LX
    Body Style:
    @K24seven might be able to help with this.
  3. Erouse91
    Erouse91 Well-Known Member
    83
    Baltimore, Maryland
    I installed them about 2 months ago. Very nice fit, very good light output, still looks stock from a distance but very unique with the lights on. Id buy them again.
    ADExternal likes this.
  4. Hillstones
    204
    Valencia, CA
    Vehicle Model:
    Maxima Platinum
    Body Style:
    Would you be able to post some pictures of the tail light installed, along with the LED illuminated? I would appreciate it. I assume the reverse and turn signals remain regular bulbs and the brake light/running light is the LED? (The Accord version combined the turn signal and brake light into a single LED).
  5. K24seven
    K24seven Well-Known Member
    134
    Pasadena, CA
    Vehicle Model:
    Body Style:
    FG4
    Two threads about this. Check 'em out.
    http://9thcivic.com/forum/threads/finally-led-tails-for-12-coupe.10117/
    http://9thcivic.com/forum/threads/got-my-led-euro-bmw-style-tail-lights-today.10810/
    Dennis Rockholt and webby like this.
  6. Hillstones
    204
    Valencia, CA
    Vehicle Model:
    Maxima Platinum
    Body Style:
    Thanks K24seven! Through your posts, I found the other links you listed above. I tried searching the forum for Eagle Eye, since that is the manufacturer of the LED tails and came up with nothing. I did not think to search LED tails. Do you remember the seller on eBay? I think I saw in one of your posts that you got them for $189, and lately I am seeing them for $269. I bought my Accord LED tails from revotec, and he was a good seller. I have also heard good things about Sabersport as well. I really like the fit of the lights for the Civic, they look much better than the Eagle Eye tail lights I had on my Accord coupe. They definitely improve the look of the Civic. I have the EX-L with the LED high-step tail light integrated into the rear spoiler, so the LED tail lights will better compliment that light.
  7. K24seven
    134
    Pasadena, CA
    Vehicle Model:
    Body Style:
    FG4
  8. Hillstones
    204
    Valencia, CA
    Vehicle Model:
    Maxima Platinum
    Body Style:
    I installed the Eagle Eye LED tail lights today and I am very impressed with the quality and light output. My challenge during the install was removing and reinstalling my subwoofer, after the audio shop installed it. Thankfully, it was an easy job, just time consuming with the subwoofer. Without a subwoofer mounted to the sidewall, it would have been a much faster job. Remove the clips with a clip removal tool, remove the center plastic by the trunk latch, and pull back the trunk liner on each side to reveal the tail lights. Remove four bolts for each lamp and the tail light assembly comes right out. (The Accord was a pain because you had to remove the bumper cover to remove the tail lights. Thankfully, the Civic does not require the removal of the bumper cover). The Eagle Eye lights are true plug and play. Unplug the brake, reverse, and turn signal harnesses and plug them in to the Eagle Eye lights. Bolt the new lights in place and replace the trunk liner and you are done.
    OEM stock tail lights with the single bulb for each brake light. Brake depressed.
    The OEM tail light with the single bulb. Brake depressed.
    Pull back the trunk liner and the tail light assembly is revealed. Remove the four bolts and the tail light comes out easily.
    Eagle Eye LED tail lights installed. Brake depressed. They have a much brighter output than the stock bulbs.
    Close up of the Eagle Eye LED tail light installed with the brake depressed. They have an excellent fit.
    Eagle Eye LED tail lights installed. I cannot remember if I had the head lights on to show the running light illumination.
    Photo of the "running" light illumination. It is a BMW-style LED illumination for the running lights. They look really good in person. I can't wait to see them at night.
    Brake pedal depressed. I think the running lights turned off because I did not have the engine running in the closed garage.
    Photo of the Eagle Eye LED tail light. It has an excellent fit, very close to the OEM light.
    One difference with the Eagle Eye lights and the OEM lights are shown here. The OEM light is completely red on the side meeting up with the trunk lid. The Eagle Eye is red translucent plastic. It is not noticeable unless you really look. But they are very close to OEM, and I like that. I love the LED tail lights, but I don't want them looking ricey, and the Eagle Eye lights look identical to OEM.
    These lights are well worth the purchase. They have an excellent fit and they provide brighter and faster light output than the standard bulb lights. Of course if you own a sedan, you always have the option of buying the OEM LED tail lights for the Hybrid model, but I don't know if a non-hybrid Civic is wired for the OEM LED tail lights in the Hybrid model. They are also expensive, $180-$250 for one light assembly.
    momo, ADExternal and K24seven like this.
  9. K24seven
    134
    Pasadena, CA
    Vehicle Model:
    Body Style:
    FG4
    Very nice to see that you are happy with the results. I've had mine for about 4 months and they're running just fine. I've gotten many compliments!
    Hillstones likes this.
  10. innoAR
    259
    orange county
    Vehicle Model:
    LX
    Body Style:
    this look is really growing on me... are you swapping out the entire headlight housing? or just somehow inserting that led strip?
  11. Hillstones
    204
    Valencia, CA
    Vehicle Model:
    Maxima Platinum
    Body Style:
    They are well made lights. I had the ones in my Accord from 2009 to 2013 and never had any problems with them. I took some night shots, and they are of course much better at night. The brake lights are really bright, which I like. They look awesome on the Civic, so much better than the OEM lights. Highly recommended, especially for Civic owners that have the OEM high-step LED light in the rear spoiler.
    DSC_7974.jpg DSC_7977.jpg DSC_7978.jpg DSC_7986.jpg DSC_7990.jpg DSC_7991.jpg
    webby and ac3jason like this.
  12. Hillstones
    204
    Valencia, CA
    Vehicle Model:
    Maxima Platinum
    Body Style:
    I only purchased the tail lights. I do not modify my headlights.
  13. innoAR
    259
    orange county
    Vehicle Model:
    LX
    Body Style:
    Yeah I meant taillight housing. My bad. LOL. Do they provide you with a brand new set of tails or is it just that led strip.
  14. Hillstones
    204
    Valencia, CA
    Vehicle Model:
    Maxima Platinum
    Body Style:
    It is a brand new set of tail lights. They even included the reverse and turn signal bulbs so you don't have to transfer your existing bulbs. Here is a picture of the OEM tail light and the Eagle Eye LED tail light. The OEM is on the left and the Eagle Eye is on the right. The eBay listings include both the left and right hand tail light assemblies.
    webby likes this.
  15. innoAR
    259
    orange county
    Vehicle Model:
    LX
    Body Style:
    thanks. damn. i am so tempted now... lol. it looks good. just worried about how long ebay LED's will last haha.
  16. Hillstones
    204
    Valencia, CA
    Vehicle Model:
    Maxima Platinum
    Body Style:
    I had the Eagle Eye LED tail lights installed in my Accord from 2009 to 2013 and they were still working when I traded in the car last July. Eagle Eye is the manufacturer and they are a wholesaler so they are sold by different sellers through eBay. The distributor is in Southern California and they are shipped from Southern California. The seller was in Hacienda Heights. I believe the lights are made in Taiwan. They are very well made, very close to OEM quality. I highly recommend them compared to any other lights you find on eBay. I just realized you are in Orange County. I do a lot of work in Orange County.
  17. Danny Hsu
    Danny Hsu Well-Known Member
    82
    Do these come with LED bulbs or do you have to buy them separately?
  18. twister8008
    twister8008 Well-Known Member
    857
    Omaha, NE, but I am a Wisconsinite
    Vehicle Model:
    Civic SI
    Body Style:
    Based on the post above, it sounds like they come ready to connect with bulbs included
    Danny Hsu likes this.
  19. 9CIvic
    9CIvic Well-Known Member
    7
    Oh those look really nice!
Share This Page
