K&N drop in filter
Discussion in 'Intakes & TB Spacers' started by Loppysaurusrex, Mar 31, 2016.
  1. Loppysaurusrex
    Loppysaurusrex Well-Known Member
    205
    So since my 2013 si is my daily I don't want to play too much with the engine or with bolt on's but I hear the drop in filter from k&n gives a very nice VTEC cross-over noise, can someone confirm?
    Also note I have a 2013 si so this is before Honda did the exhaust upgrade
  2. webby
    • 2018 Toys For Tots
    webby Administrator
    50,003
  3. Loppysaurusrex
    205
    The whole point of the drop in is not having to do a lot of work
  4. squiggy
    squiggy Cartographer
    10,886
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    The resonator delete is not a lot of work...
    webby likes this.
  5. webby
    webby Administrator
    50,003
    I was just adding a free suggestion in addition to the filter. It could prob be done in like 15 min or less.
  6. Loppysaurusrex
    205
    Maybe for you, would probably take me hours
  7. Jake LXer
    Jake LXer Jaykwabee and the R18
    497
    New York
    Vehicle Model:
    civic
    Body Style:
    sedan
    I don't even think i used tools to do this, maybe a screw driver for MAYBE 1 or 2 screws/clips but the pipe literally just pulls off if i remember correctly. It's a lot easier than having to learn how to drive stick shift which i know you've done seeing as you have an Si
  8. Michal006
    Michal006 Well-Known Member
    9,565
    PA
    Vehicle Model:
    Tacoma TRD Sport 4x4 6MT
    Body Style:
    Access Cab
    We all had to start somewhere... that's how you gain experience and learn how to work on your own car. Try it:)
  9. Loppysaurusrex
    205
    And what of the jack and removing the wheel?
  10. Loppysaurusrex
    205
    Does the res delete even make it sound better?
    I've heard some sound clips but it doesn't sound much different
  11. Jake LXer
    497
    New York
    Vehicle Model:
    civic
    Body Style:
    sedan
    Bro my grandma rotates her own tires, thats the easiest step! Lol but in all seriousness this is a straight forward process and it does make it sound different a little bit but combined with the drop in filter and the res delete it will sound better
    Loppysaurusrex likes this.
  12. webby
    webby Administrator
    50,003
    There is a jack in your trunk to remove the wheel.
  13. Jake LXer
    497
    New York
    Vehicle Model:
    civic
    Body Style:
    sedan
    ^What Webby said, but if you have a floor jack i'd recommend using that with a jack stand. Makes it easier on you and IMO i think it's safer
Share This Page
