Privman
Active Member
Ingredients needed:
10003-RRB-A02 Cylinder head assembly 2010 Civic Si
15810-PRB-A03 VTEC oil control solenoid 2010 Civic Si
18712-RBB-000 Water outlet 2008 TSX
18714-RAA-A01 Water outlet gasket 2008 TSX
13450-PNA-004 Oil pump chain tensioner 2006 RSX
13460-PNC-004 Oil pump chain guide 2006 RSX
13441-PCX-004 Oil pump chain 2006 RSX
15100-PRB-A01 Oil pump 2006 RSX
11221-PNC-000 Windage Tray (Plate, Baffle) 2006 RSX
06110-RBB-010 Gasket kit, cylinder head 2008 TSX
06114-R40-J01 Gasket kit, chain case 2012 Civic Si
17125-RRB-A00 Intake manifold stay 2010 Civic Si
17100-RRC-000 Intake manifold
16450-RBB-003 Fuel injector (4) 2010 Civic Si
13322>7-PRB-A01 Main bearing upper 2012 Civic Si
13342>7-PRB-A01 Main bearing lower
13212>7-RBB-003 Rod bearing
Injectros (race spec)
Oil Pan Baffle 2012 Si (race spec)
Engine Wire Harness 2012 Si (race spec)
Engine Belt (52.5) 2012 Si (race spec)
Manifold, Exhaust 2012 Si (race spec)
Pistons, Rods (race spec) 12 to 1. No problem with the correct piston shape and will run on pumpgas.View attachment 9266
