Led guidance
Discussion in 'Lighting, HID's, And Retrofitting' started by Matsweeper, Feb 20, 2019.
  1. Matsweeper
    Matsweeper Well-Known Member
    281
    New Jersey
    Vehicle Model:
    Civic
    Body Style:
    Hey guys. My break light went out and I had to buy a new one so I have my interior with Philips LED and I love them. I wanted to stick with Philips LED so I purchased their 7443 red and it works great. I was planning on changing my 3rd breaks light. The bulb says 7440. Just want to check if anyone changed that on theirs with LED.
    My last question. I wanted to concert my turn signals to LED from Philips. Which are Amber 7443. Philips makes a canbus. Has anyone used this and does it work no problem and last the total time of bulb life? I don't want to buy this only to burn something out within months.
    Sent from my Pixel 2 XL using Tapatalk
  2. webby
    • 2018 Toys For Tots
    webby Administrator
    49,865
    some have done blinking 3rd brake lights, but yes 7440/7443 will work.
    http://9thcivic.com/forum/threads/blinking-brake-lights.15564/
    as for turn signals -
    if you want to trick the car, you can get load resistors like this from TRS
    https://www.theretrofitsource.com/morimoto-led-load-resistor.html
  3. Matsweeper
    281
    New Jersey
    Vehicle Model:
    Civic
    Body Style:
    Thanks for the reply. I ended up getting the 7440 led red from Philips. Can't wait to.get it to replace the original bulb on my 3rd break light.
    As for the turn signal, thereteofitsource canbus sounds like quality but I don't want to risk it just for looks. Might just replace it with regular halogen bulbs when they burn out. When I have my bimmer I purchased these metallic painted bulb which looked great and where very slightly dimmer than OEM. Not enough to deter.me.from buying them again. Might try that option. I would like the I start on/off turn lights but don't want to worry about something failing. The yellow bulb in the rear and front corners though... That I would like to.see.if I can change.
    With the snow here in NJ I'm waiting to wash the car.as.i have made some cool mods and can't wait to post pics.
Share This Page
