I was hoping you guys might be able to help me.
I want to mount a few small LED light bars on my 2013 Honda Civic LX sedan (no fog lights or interior illumination or anything)
2 very small ones would be wired in conjunction with the headlight low beams, and that shouldn't be a problem, just use a fuse tap on headlight low beam fuses in the engine compartment right? Should I tap both the left and the right just to ease the strain, or just wire both light bars on one of the fuses (like the left? The power consumption on these two would be less than 5 amps.
That should be the easy part for me... then next one is what I'm stumped on....
I then want to wire a much larger light bar to be switched on with my High Beams (probably UP to 10 amp draw on the light bar). This fuse is in the car... and much of the circuit seems to be shared when operating as DRLs and as actual Highbeams. Would I just tap the fuses for the high beams that are in the interior fuse box(fuses 38 and 39)? And again, tap one or both (and wire them together and then run one wire)? I guess my real concern is that the lower voltage of the DRL (which I want to keep) would be running through the fuse for the high beam.
And then my last concern, it would make all this moot... Are the fuses before the switches or after the switch? Like if I tap into the fuse for the low beams, is it going to get constant power with ignition, or power only when my low beams are on? And same question for the high beams.
Thanks for the help!
And btw, I live in the middle of bum*&%# nowhere where the animals practically live in the streets, so that's my desire for the lightbars.
At some point I may just unplug the fuse for the daytime running lights (to save the bulb of my regular high beams), and just tap into an unused fuse that is switched on ignition to power even smaller LED lights, but that I'm not concerned about... I know what fuses to tap into at that point as it's only on or off with the car.
