Jeffuhnator
So I recently installed some "Oem Projector Headlights"... except mine are replicas off of ebay. The headlight itself are well made for replicas and mine has a little chip, but no one will notice it unless they look up close or if I point it out like how I did in the video.
The beams that are given off when I turn on my low beams are scattered unevenly.
However, I've read the cause of this can be from putting hid's in "halogen projectors" or it could be from the headlights themselves as they are replicas. .
The next best thing I can do is just adjust the height and align them. I have not messed with it yet, but the height seems fine to me, maybe just a little lower and it should be good.
***!!!WARNING: A LOT OF HARNESSES!!!***
For my low beams. I used "H11: Morimoto Elite HID system" which consisted of:
- HD Relay
- xb35 5000k (Was aiming for as white as possible.) Will try 6000K next time. I think they're more white?
- 3Five Ballasts
P.S. The HD Relay made things more complicated when installing. I on't think it's necessary to have, but the point of the relay can be read here: http://www.theretrofitsource.com/morimoto-h11-low-beam-relay-wire-harness.html#.UvN5dmSwKi0
I already forgot, but I believe I ended up having 1 connection unused on the passenger's side and 2 connections unused on the driver's side because of this relay. Because instead of using "power/electricity" from the stock plug-in harness, you're using the new plug-in harness provided from the hd relay which draws power straight from the battery.
P.S.2. You'll need a 9006 to H11 Harness:
http://www.ebay.com/itm/130605414822?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Day Time Running Lights (DRL's)/High Beams:
High Beams are useless now, since I have led's. Which I got from here:
http://www.ebay.com/itm/380760002089?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
I was aiming to get white as well to match with my low beams, but now that I thought about it. I'll never have both of them on at the same time unless I use my high beams, but my high beams aren't even functional so...
P.S. They barely made it into the housing, I scraped a little bit of material when twisting them into the housing and the dust got onto the inside of the lens housing (since I installed it with the whole headlight housing off and facing down). You can use compressed air to blow it out, but I just blew inside the parking light housing (helped a little, but no one's gonna notice).
P.S.2. You'll need a harness for this as well:
http://www.ebay.com/itm/300869415432?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
You can get it here or from ijdmtoy, but if you look for better deals on ebay, this is the only listing I was able to find, just letting you guys know.
Parking Lights (194) and Signal Lights (7440):
I actually got 194NA and 7440A which are amber versions which are why they both end with "A". They're Silvania brands and got them from autozone.
P.S. You'll also need a harness to run these as well: http://9thcivic.com/forum/threads/2012-civic-oem-halogen-projector-headlights.4834/#post-81136
Here's one listed up for sale on ebay:
I bought my harness from this same person, I was going to make it, but I decided to just not mess with my stock harness.
P.S.2. I'm not the seller lol. His name just happens to be Jeff too.
FIN.
