fabian
- 2
Ok so i bought the Viper model 5706v and a dball2 bypass module. I am doing d2d connection between the module and the viper. I have most of the wires figured out except for a few. The wires i am having problems figuring out are the wires on the 10-pin harness from the viper. I cant figure out which one goes to the accessory1 and accessory 2.
Viper remote start harness, 10-pin connector --> Car Wire
PINK(+) ignition 1 input/output --> ignition
RED/WHITE(+) fused (20a) ignition 2 / flex relay input 87 -->+12v constant
ORANGE(+) accessory output --> ??
VIOLET(+) starter output (car side of starter kill) -->split starter wire and connect to starter side of wire
GREEN(+) starter input (key side of starter kill) --> connect to push to start button side of the split wire
RED(+) fused (20a) ignition 1 input --> +12v constant
PINK/WHITE(+) Ignition 2/ flex relay output --> ??
PINK/BLACK(+) flex relay input 87a keyside (if required) of Flex relay --> ??
RED/BLACK(+) fused (20a) accessory/starter input --> +12v constant
NC --> No Connection DO NOT USE
ok so i read domewhere that the 3 wires that are fused (red, red/white, red/black) will go to the ignition wire?
would the orange accessory output go to accessory1?
what goes on accessory 2? would that be red/black (+) Fused 12v accessory/starter input?
i uploaded a excell screenshot of how i have the wires right now.
