Oil pan Gasket
Discussion in 'Mechanical Problems & Technical Chat' started by aalamilla, Aug 10, 2019.
  1. aalamilla
    aalamilla Member
    2
    Hey i want to change the gasket on my oil pan since its leaking. I don’t know how to drop the frame though. I cant find much about it online. Can someone instruct or share a video about it?
  2. webby
    • 2019 Toys For Tots
    webby Administrator
    50,404
  3. mySIck
    mySIck Well-Known Member
    1,574
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    Dropping the subframe is not bad at all. I used Mark's video that Webby posted and it made it easy the first time I did it.
    I would definitely get 2 Jack's if possible to make the install easy if you are doing it alone.
    webby and aalamilla like this.
  4. aalamilla
    aalamilla Member
    2
    Am i supposed to put some kind of Glue on the gasket?
  5. webby
    webby Administrator
    50,404
  6. dpetro1
    dpetro1 Well-Known Member
    417
    Catonsville, MD
    Use either a gasket OR Hondabond, not both
  7. mySIck
    1,574
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I used hondabond on mine it is holding up well.
Share This Page
