Opti-Coat 2.0 with PPF?
wbarraza
20
I am thinking of using Opti-Coat 2.0 on my black SI but I also want to put on the PPF 9th civic has. Would I be able to opti-coat my car and then add the clear bra?
Thanks in advance!
not quite sure how ppf would adhere to the opti. Usually shops claybar, and clean the paint prior to applying the ppf film. RaskyR1 could maybe chime in on what the paint feels like with opti, or if he thinks it'd be fine to apply ppf over it.
You can OC both before and after having PPF installed and it will not effect the installation process.
However, with vinyl wraps/stripes you would not want OC applied before installation, but it can be applied over them.
Not sure what is different between the two adhesives but that's the info I got from Dr. G.
vinyl film is definitely different than the backing on paint protection film... but yea. Thank you for the input
