Pauly's "You're my boy Blue!"
Discussion in 'Build Threads' started by Pauly99to17, Jan 25, 2013.
  1. Alabaster Master
    Alabaster Master Well-Known Member
    4
    Oh, gotcha. It's been a long time since I've installed a system in my car. I always did one large fuse that was rated to cover all amps/crossovers combined by the battery, ran that cable to a distribution block then inline fuses (when necessary) to each of the individual amps and crossovers. I miss my system.
    Pauly99to17 likes this.
  2. Pauly99to17
    Pauly99to17 Well-Known Member
    9,170
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    Dyno Blue Pearl Sedan (FB2)
    Well, its my first time installing one so I'm certainly no expert. Your way sounds like a good option too.
  3. xXCiviXx
    xXCiviXx Well-Known Member
    890
    Calgary, AB, Canada
    Vehicle Model:
    Si
    Body Style:
    You could also get a fused distribution block. 1 larger power cable to the battery that splits at the distribution block with maxi fuses to smaller gauge power wires. But 2 dedicated power wires should be fine
  4. Alabaster Master
    4
    Yeah, I know it is. I didn't mean for my comment to sound rude or anything. Just wanted to offer up an option for installing. This page is worth checking out:
    http://www.bcae1.com/fuses.htm
    Diagrams what xXCiviXx and I referred to with the distribution block.
  5. aznboi606
    aznboi606 Well-Known Member
    358
    Atlanta, GA
    Vehicle Model:
    Honda Civic Si
    Body Style:
    That sh*t is rusted out.
  6. Pauly99to17
    9,170
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    You talking about the brake rotors and suspension? Ya, welcome to Quebec. So much salt used on streets during the winter. It's brutal on cars.
    xXCiviXx likes this.
  7. Pauly99to17
    9,170
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    Rear deck removal today. Replaced rear speakers.
    xXCiviXx and webby like this.
  8. Pauly99to17
    9,170
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    I have been doing some reading about sound insulation. I wanted to find a cheaper alternative to Dynamat. I read about a number of people using an asphalt based "Peel ansd Seal" type of product but I didn't want to have the smell or possible carcinogens in my car so I ruled those products out. I ended up getting Reflectix which is a product for insulating ducts. It's really inexpensive ($20). I wanted to get another product which I read good things about and Sounds better that what I got, but it's unavailable here and I needed. Something now. Home Depot has it (only in the US though). It's called Frost King Duct insulation.
    This is what what I got
    What I wanted, but not available
  9. xXCiviXx
    890
    Calgary, AB, Canada
    Vehicle Model:
    Si
    Body Style:
    In for updates!!! I used GTmat Ultra as a less expensive product than DynaMat but that duct insulation is still about 1/6 the cost (depending on surface area)
  10. Pauly99to17
    9,170
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    Productive day. :)
    Front speakers installed. Pictures for later reference. Lots of splicing with the 2 extra wires in each door that supplied door control lights and door ambient light. All that's left now is to hook up the power cables and hook all the wires into the amps and connect the sub. For the moment I have the front speaker signals spliced into the rear speaker signal. Already sounds a little better even with that terrible rear signal and non amplified. I can't get over how cheap the stock speakers are.
    webby, andre12dbsi and Darkout like this.
  11. Darkout
    • Supporting Member
    Darkout Supporting Member
    1,107
    Cocoa, FL
    Vehicle Model:
    Body Style:
    Right on bud! Looks like you've been busy. This is a must do at some point for everyone cause like you said, the stock gear sucks!
    The only way I've found to get the stock system to sound anything ok is putting the sub to max, fading a few clicks to the rear to tone down the fronts a smidge and only use bluetooth with the phone. For whatever reason bluetooth has better output signals that will actually give an almost proper base thump and fullness of sound.
  12. Pauly99to17
    9,170
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    System is installed. So happy with the results. The install went fairly smoothly although it was a long process. I thought that I wouldn't need a remote wire because I used the high level inputs. Turns out I needed one.
    I used the ground bolt right behind the seat. I sanded the paint off under the bracket. Works like a charm and is well situated. All that is left is the cable management.
    webby, xXCiviXx and andre12dbsi like this.
  13. andre12dbsi
    andre12dbsi Well-Known Member
    2,096
    Gatineau, QC Canada
    Vehicle Model:
    '15 Acura TLX SH-AWD Tech
    Body Style:
    Another job well done Pauly!
  14. Pauly99to17
    9,170
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    Thanks Bud!
  15. webby
    • 2018 Toys For Tots
    webby Administrator
    49,831
    did you take pics with the sound deadening installed?
  16. Pauly99to17
    9,170
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    No, I haven't done the trunk yet. You can see a little of it in a picture above where I put as much as I could inside the door of the speaker hole opening.
  17. Pauly99to17
    9,170
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
  18. squiggy
    squiggy Cartographer
    10,838
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
  19. xXCiviXx
    890
    Calgary, AB, Canada
    Vehicle Model:
    Si
    Body Style:
    Speakers so loud, they blow women's clothes off
    Pauly99to17 and Michal006 like this.
  20. Pauly99to17
    9,170
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    Ha-ha! The amps have a blue light each on each side, but ya, you're right. I'm already thinking of moar lights to add. :)
Share This Page
