Ported Intake Manifold
mazda_lexus
53
Can someone explain to me what ported intake manifolds are? And how it's done? I see all these aftermarket ported manifolds but I don't know what it is and the benefit. I want to start planning my build and whether or not I'm going FI
Porting is simply the process of changing the size and shape of the intake runners in the intake manifold or the cylinder head to produce better airflow. More airflow usually results in more power and can be beneficial depending on your build. If your car is stock at the moment there is a good chance that you have a plastic intake manifold. I don't believe porting is recommended if you have a plastic manifold.
They'll cut open the rbc manifold and polish all of the internal runners in hopes to improve air flow. Then they'll weld the unit back together something like below:
Interesting. It just dawned on me why Skunk2 designed the ultra the way they did.
It's usually meant for more air flow, but the trade-off is reducing the turbulent flow going into the combustion chamber. Turbulent flow = better mixture of air and fuel. That's why many engines are getting ported and polished for performance only on the exhaust side. In technicality for better performance, intake side = turbulent flow, exhaust side = laminar flow. Cross sectional area is also a big factor for a higher volumetric flow rate for a better performance gain.
I did mine using a long reach grinder.
10405505_10152480914142168_4245977938632309220_n.jpg 11062062_10152480914667168_1473483544944822187_n.jpg 11390319_10152480914222168_2122902965872399036_n.jpg 11393260_10152480914407168_2205889379439790067_n.jpg
There are a few better places to spend $$ first if you're after more power.
Definitely considering going on either a PRL stg 2 turbo kit/ Full race turbo kit
Or the CT-E SC
