sininspira
New Member
- 1
- 0
Hi everyone, new to the forums. I'm looking to replace my entire audio setup, possibly in stages because I'd like to do it myself. I have a 2012 EX-L Coupe w/Premium Audio (non-navi). This would be my first entire-system replacement. I've done like one or two head units on old cars, but that's it. I have a good amount of home theater/AV knowledge, and can keep up with high level EE stuff though.
Anyways, I had a few questions.
1) Since I'm replacing the head unit and amp, do I need to worry about the differential balanced outputs talked about in this guide? http://9thcivic.com/forum/threads/2013-civic-premium-audio-system-navigation-stereo-upgrade.10207/
2) Can I replace just the head unit and amp, and leave the stock speakers for later? I know stock is bad, but I'm mainly interested in a head unit for Android Auto and if the sound quality with a new amp/head unit is comparable to stock I'll still be happy until I can replace the rest.
3) I'm pretty sure the answer is no, but can I connect the factory mic to a new head unit? If not, are internal mics to head units usually acceptable quality for calls and voice commands? Is it better to get an external mic compatible with the head unit and mount it?
4) Any recommendations for a backup cam that could hook up to a head unit and be triggered on reverse? I've seen some that get power from the reverse lights, but I'm not sure how that all goes together with the stock system and/or new head unit.
5) Any features in a head unit I should be looking for to keep steering controls with the crutchfield adapter? Along the same lines, any other essential adapters/harnesses?
6) Any other recommendations for someone just starting out?
Thank you in advance for any help/answers!
Edit: additional question - Can I also just replace the head unit and leave the amp/speakers be for now and keep the same level of audio quality the stock head unit provides?
