Rear Sway, short throw shifter, and engine mount help
twister8008
480
Omaha, NE, but I am a Wisconsinite
Civic SI
I would love to upgrade my suspension a bit. I have an HFP suspension currently with no other mods. I would like to tighten up my suspension with a 24mm rear sway bar. I also would like to shorten up my shifts. I am looking at the buddy club and billet pro sets. Finally, I am looking to install the Boomba Racing engine mount. Can anyone provide guidance, advice, or a testimonial on these products? Thanks for the help!
The 22mm is a better choice for a rear sway bar, imo. Unless you'll be tracking your car in an occasional manner. It's also about $100+ cheaper than the 24mm. With that you can get better sway bar bushings and beefier end links from MOOG. Here's a thread I made regarding the Progress bushings: http://9thcivic.com/forum/threads/rear-sway-bar-bushing-upgrade.10188/
Depends on the year!
'12 go with the 22mm
'13 go with the 24mm to compensate for the increased FSB size.
Better off spending your money on the rear lower mount from Hasport. Most people will tell you Boomba is junk/bling.
I thought the 2013+ have hollow tubed sway bars.
I could be wrong. Lol.
IIRC, I read on here about that, and there was a hollow tube, but not the same brand as "Progress".
