1. dvlsfan30
    dvlsfan30 Well-Known Member
    21
    got a 2014 sedan si i am looking to lower with buddyclub coils when they are available for the 14.
    i have decided on Black RPF1s, i know my car has 18's but im not crazy about how big 18s are on the civic.
    i like the look of 17s and have been flip flopping around on width.
    couldnt decide on 8 , or 9. i love the look of the 9 but dont want to roll fenders or camber out.
    would 18x8.5 fit close to flush with the fenders and not require a roll? i like the look of the flat spokes on the rpf1 but you only get that on 9 inch width.
    im also confused about offset. what would look more aggressive 30 or 40mm? i want to run buddy club brake calipers so clearance is in mind too.
    any help is greatly appreciated as in i know nothing about offset really.
    im not looking to stretch really either!
  2. dvlsfan30
    21
    or would i be able to run 17x9 and still be able to clear coilovers, new brake calipers and no fender roll if i didnt go
    'too low"
    i really love the look of the rim 9 inches wide the flat look
    team3d likes this.
  3. webby
    • 2018 Toys For Tots
    webby Administrator
    48,844
  4. team3d
    team3d Well-Known Member
    711
    Los Angeles
    if you want to run buddy club calipers, you can only use these sizes for RPF1...
    17x8 et35 or 17x8.5 et40 or et30
    17x9 will require spacers to clear calipers
    and as for black rpf1, they are very limited in sizes..... i believe we only have 2 sizes for black rpf1
    webby and Nix like this.
  5. dvlsfan30
    21
    do you think i could get away with 17x8.5 without rolling if i lowered on the coils? what would be a nice tire without stretching?
  6. Nix
    Nix Jötunn Moderator
    10,765
    Lew-vul, KY
    Body Style:
    It's A Fast Pig!
    @team3d - Great info! Question: Why does the 17x9 not clear the caliper? Does it have to be a particular offset or is the difference in the wheel shape that reduces clearance on the backside?
    Probably depending on the offset. Get the +40 to be safe and also leave yourself room to run a big tire if you wanted to. You could do either a 225/45/17 or a 235/40/17. The wider tire is a little short compared to stock but gives you the largest contact patch and a slightly smaller sidewall. Best option for performance but not ideal if you are driving a ton. The 225 on an 8.5 will fit really nicely too.
  7. dvlsfan30
    21
    can you run 17x9s without rolling fenders if i lowered it?
  8. Nix
    10,765
    Lew-vul, KY
    Body Style:
    It's A Fast Pig!
    People have but it really depends then on offset, tire size, how low is "low enough", and camber settings. So technically yes. The +35 and a 215 or most likely a 205 tire would make it. I don't like the idea of stretched tires myself and the narrowest I would suggest running is a 225 width. You will most likely rub with that though.
    I don't like stretched tires and I don't like camber over -2 degrees. That's just me. Where are you located? If you're anywhere near Louisville KY, I would be happy to help you roll your fenders.
  9. dvlsfan30
    21
    im in new york, and would love the help if i was out there. im just nervous having someone roll the fenders that they will get damaged in the process. i have seen what they can turn out to be if a shotty person does it.
    i dont want to stretch either.
    i dont need to slam, the reason i would do a 17x9 instead of 18 on my 2014 is so the car sits lower to the ground to begin with so i dont need to dump the car. i would like the top of the fender to just above the tire. if i did 17x9 i would have to sacrifice doing the buddy clubs. i love the look of the 17x9s but cant win i guess lol would probably rub bad. i want to run buddy club coils as well
  10. Nix
    10,765
    Lew-vul, KY
    Body Style:
    It's A Fast Pig!
    NY eh? What part? NYC or Upstate?
    With 17 vs 18 if you maintain the correct tire size the car will not be any lower to the ground. You will keep nearly identical outer diameter, which keeps your speedometer accurate, and your mileage accurate also. A 17 will only be lower than an 18 if you make the sidewalls the wrong size. You can run either size wheel and keep that gap the same depending on tire size. Do you have a coupe or sedan? I generally think coupes look fine with 17s but I like the look of an 18 on a sedan. The body size is larger and I think the 18 just "fits" better.
  11. team3d
    711
    Los Angeles
    if you don't want to stretch your tires, then why get 17x8.5 ? the reason people buy 17x8.5 so they can fit wider tires properly...
    17x8 with 225/45-17 is perfect set up. no fender roll & no rub
    go 235 when you have 230whp+
    & if your in nyc... this set up will be an ideal for city driving... you don't need to worry about pot holes or curbing your rims... you can just drive normally like a stock car. i don't even slow down when i see pot holes, i just drive through it... i hate driving like a turtle
    Nix likes this.
  12. dvlsfan30
    21
    i live in upstate ny. and i will be purchasing new tires with the new rims. the driving aint too bad up here but there is some pot holes. im about an hour away from nyc and its becoming like the city with everyone moving here
    i do like the 18s but for some reason i like 17s better. i saw a pic on 17x8.5 and they looked nice and close to flush. im all over the place lol i may just end up with the 17x8
  13. Nix
    10,765
    Lew-vul, KY
    Body Style:
    It's A Fast Pig!
    The rpf1 looks totally different in a 9" width than an 8 or 8.5, be certain you are getting the wheel you want. Bubble face vs concave/flat face spokes.
    Also, I'm from Syracuse and I'm up there occasionally. If you were closer I'd say we could meet up and get your fenders rolled for you.
  14. dvlsfan30
    21
    i appreciate it man , unfortunately im an hour and 40 min south of albany.
    i will probably run the 17x8.5 or just got 18x8 like stock if i decide to stay 18
    what would be a safe, good tire size for the 17x8.5 without worrying about rubbing or stretching? im guessing the 18x8 the stock size tire would look nice on the 18x8 rpf1. it looks good on the stock rim in my opinion.
    Nix likes this.
  15. Nix
    10,765
    Lew-vul, KY
    Body Style:
    It's A Fast Pig!
    On 17's run a 225/45/17 but, if you went to 18's get a 225/40/18. It fits nice and maintains the correct outer diameter. Be sure and look at what I told you about the different widths with that particular wheel though ok?
    This is a 17x8. See how the spokes "bubble" out?
    [​IMG]
    [​IMG]
    And this is 17x9. Watch how different the wheel looks. It's the same whether 17 or 18".
    [​IMG]
    [​IMG]
    Seriously google both sizes and make sure you are getting what you want. The wheel looks completely different from 8.5 and 9" wide. That half inch is the biggest change of any wheel I know.
    webby likes this.
  16. webby
    webby Administrator
    48,844
    ^ what he just said
    Dennis Rockholt likes this.
  17. team3d
    711
    Los Angeles
    17x8 et35 with 235/45-17 (tires too tall, 235/40-17 is the correct size)
    [​IMG]
  18. team3d
    711
    Los Angeles
    18x8.5 et40 with 225/40-18
  19. dvlsfan30
    21
    i actually like both looks, but for me with a car that has 1300 miles on it, i am probably going to go with the 8 inch or 8.5 for drivability reasons if that makes any sense lol
    i am starting a new job for the railroad the 24th and even though i will be taking the train, i will need to commute to some places during training.
    im either going to go 18x8 or 17x8.5 (if i can figure out a tire that wont slighty rub) i guess i got time since the buddy clubs aint ready yet and i wouldnt want to throw them on without lowering the car at the same time while its in my friends garage.
    i found someone running 17x8.5 on another forum but he doesnt log in anymore so i cant even ask him how the rpf1s were in 17x8.5 rubbing issues etc
  20. team3d
    711
    Los Angeles
    if you see 17x8 & 17x8.5 in person, if no one tells you the size, you will not know the difference...
    many people gets hung up on "wider" wheels so that have to have that extra 1/2".... that 1/2" when really look at it, it's only 1/4" more outward & 1/4" inward.... you barely can see it....
Share This Page
