iWANNAsiR
So I bought my 2012 Si with 3 original miles, still in the wrapper. Now I am just over 5000 miles and I ran into a bunch of electrical issues, hopefully one issue with many symptoms. My car is a rebuilt flood car from Hurricane Sandy, all work was done by myself, with an exception of the programming of things the dealer had to program. All electrical items were replaced with new OEM parts except all sensors, the airbags, the ECU and the three displays. Everything worked until now so I believe one issue is causing all symptoms. Car runs and drives fine here are my symptoms:
-Unable to connect scan tool, $200+, Advance Auto Parts scanner, worked with car before I can check the exact model later.
-A/C stopped blowing cold.
-Speedometer and tachometer do not work. Tach will move a bit if I operate sunroof or windows and then will go back to 0rpm.
-Steering! Light is on.
-Tire! Light is on.
-Stability/Traction control Light is on.
-Coolant C Light is on.
-BRAKE Light remains on even after E-Brake is released. Cruise Control won't work, which I assume are directly connected.
-ABS Light is on.
-CEL Light is on, was on before due to P145C (Evap code).
-Airbag Light is on.
Currently the interior is torn back down to just wiring, displays, and the metal structure (I was checking all grounds, all are clean and tight).
Any help would be appricated.
-Tire! Light is on.
-ABS Light is on.
