PainlessCandy
It has come time to get a new set of summer wheels and tires. I had always had my heart set on some Work Kiwami's, but alas the budget will only allow for so much. The size I am set on is 18x9.5 as I would like to run a 255/35 tire up front. It appears that this is accomplished with some fender work that I am prepared to do. I just want to get some confirmation before pulling the trigger.
Based on @SafeGabe 's build, it looks like this tire will fit along with a wheel of that size as long as it has an offset of +25 or lower. He was running 225's in the rear however, and I believe that size would be too much of a stretch on a 9.5" wide wheel. If I am correct in that assumption, what size tire would you recommend running in the rear? A 235 seems like the obvious choice, but would the slight difference in sizes matter front to back?
I currently have the HFP suspension with no camber upgrades. It seems like this setup will fit but I am unsure if I need to get camber arms and bolts now or if it can wait til I upgrade the suspension later this year (I have my heart set on BC-RS coils w/ Swift springs). I am not looking to drop any more than half an inch from where it sits now.
I would like to go to this route as opposed to 18x9 since my options are much more limited in that size, and the look I am going for is more easily obtained with that width of wheel. A widebody kit is in my future as well, so I'm not worried about the poke as long as it functions, and I'm ready to roll and pull the fenders.
