What is the difference Hondata carb flashpro and non carb?
Discussion in 'ECU Tuning' started by Tony-si, Aug 7, 2018.
  1. webby
    • 2019 Toys For Tots
    webby Administrator
    50,283
    So you could run the “reflash/carb compliant” if you had the carb hondata unit.
    ruddyrid likes this.
  2. Tony-si
    Tony-si Well-Known Member
    169
    North Hollywood, Ca
    Vehicle Model:
    Civic SI
    Body Style:
    coupe
    i dont have any. i guess a custom tune map would be best?
  3. dpetro1
    dpetro1 Well-Known Member
    414
    Catonsville, MD
    The carb maps are second and fourth on the list you posted...
    You can also tick the box for "show carb only" and it will only show those two
  4. webby
    webby Administrator
    50,283
    You said you wanted to buy a carb unit? The carb maps would be what you could use.
  5. Tony-si
    169
    North Hollywood, Ca
    Vehicle Model:
    Civic SI
    Body Style:
    coupe
    i asked about it because it was cheaper.
  6. dpetro1
    414
    Catonsville, MD
    Ok so the first and third maps would work for you.
    Also, if cost is a concern some tuners have a "dealer" license and they can tune your car without you buying the flashpro unit itself.
    Only negative is you wouldn't be able to make changes or flash back to stock without them.
  7. Tony-si
    169
    North Hollywood, Ca
    Vehicle Model:
    Civic SI
    Body Style:
    coupe
    if I just had a K&N and q300, what one would work?
  8. dpetro1
    414
    Catonsville, MD
    I would still just stick with the hondata reflash. Those mods aren't really going to change much or require a tune.
    Once you get into downpipes and CAI, you will need a custom tune.
Share This Page
